Quantcast tires rotated and now really bad wobble? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > tires rotated and now really bad wobble?
TJ 5.25" Speaker Adapters - NalinMFGTruck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 05-14-2007, 09:06 PM   #1
guy.griffin
guy.griffin's Avatar
so I took my jeep to a local stealership to have the oil changed and tires rotated and now I have a wobble in my front end and it gets even worse when I go down a ruff road to the point I have to pull over and stop to get the front end to quit.
So what gives? How does rotating the tires cause a wobble?
guy.griffin is offline   Reply With Quote
Old 05-14-2007, 09:14 PM   #2
Los
Did you have the tires balanced? Throwing off a weight can cause your front end to wobble. This happened to me a while back and the wobble at the steering wheel was annoying as heck.
In your case, if one of your rear wheels was out of balance, you may not have noticed it until it was rotated to the steering axle.
Just my .02.
'04 TJ, RE 4.5, 33 BFG MT's, ARB F/R, LoD F/R, D30, S35
Los is offline   Reply With Quote
Old 05-14-2007, 09:15 PM   #3
Zennashton
Make sure they tightened your lug nuts. I bought tires once and they only hand tighted them and that was a simular feeling.
If not the lug nuts then its prolly your tires working in the new rotation patern. Happen's if you wait to long to rotate.
Zennashton is offline   Reply With Quote
Old 05-14-2007, 09:22 PM   #4
guy.griffin
yeah i check the lugs tonight and swaped the front tires around because they didn't even rotate them right. They just went front to back on the same side. I was always taught that you go from corner to corner front and back.
Any way it got a little better but not much I am taking it back in a week from wed and telling them to check everything. The only reason I took in the first place because it only cost me $26.00 for an oil change and tire rotation so we will see what happens
so in the mean time I will just have to drive my car
Old 05-14-2007, 09:23 PM   #5
RedRubiconLJ
RedRubiconLJ's Avatar
And balance them when you do this.
2005 Red Rubi Unlimited Auto
WARN M8000, 3/8 Synthetic line,
Kilby, Jeeperman, Jeepmedic,
RE SF 4.5- all adj arms, RS9000x,
TW shaft, 37" MTr's, RockCrusher,
Currie, Rockhard, Alloy USA.
Jeep Pics
RedRubiconLJ is offline   Reply With Quote
Old 05-24-2007, 10:42 PM   #6
guy.griffin
So I went and picked up my jeep today I took it in yesterday. Any who the morons at the dealership told me that my tires are bald. I asked you sure you have the right jeep? there are still plenty of tread left on them. when I took it in I told them to re balance the tires well they didn't. So now I am going to take it to another place where I am not sure yet? to get another opinion on the whole tire thing and as well as the front end checked out. Needless to say i will never take it back to the local dealership for anything. They have wasted my time and made me a little pissed off!!!
Old 05-24-2007, 10:53 PM   #7
bgpifer
Lots of guys just dont care!!!
Dealers get a bad rap, but keep in mind that it lies still in the know how. Find a local person that really knows the front end. Good luck!!
bgpifer is offline   Reply With Quote
Old 05-24-2007, 11:48 PM   #8
jdragger
Mine did the same thing. Got 'em all rebalanced - one was way out. Told the tire guys they had to put weights on both sides of the wheels if necessary and get the balance as close as possible. Checked the toe in and caster (did it myself-toe in was off). Bam. Drives good. Way better.
jdragger is offline   Reply With Quote
Old 05-25-2007, 12:21 AM   #9
JeepGal
Ive learned something when you balance your tires...
Dont use the wheel weights that clip onto the edges, get them to use the stick on ones, and have them stick them on the INSIDE of your wheels. This way they wont knock off
Good luck with diagnosing your wobble
Tam
My Jeep Rocks!
JeepGal is offline   Reply With Quote
Old 05-25-2007, 12:24 AM   #10
Shane64
MINE STARTED TO ACK UP BEFORE i ROTATED MINE THEN IT WAS EVEN BUMPYER AFTER BUT NOW WITH ABOUT 1500 MILES ON THEM THEY ARE NICE FINNALY!
Shane64 is offline   Reply With Quote
Glock Forum
