Tire Wheel Combo - JeepForum.com
post #1 of 7 Old 07-14-2010, 07:09 PM Thread Starter
Leonidas
Junior Member
Tire Wheel Combo
the ever-present question looms: I'm planning on running Mamba 17" x 8 wheels with BFG ATs either 285 75 R17s or 305s. I'm wondering opinions on the tires. Do you think the 285s will be too tall and narrow? Would the 305s wear to quickly (bow in the middle) on the 8" wheels? I think the 285s and 305s are the same height, just different width? This is an 85% road vehicle.
Thanks!
Leonidas is offline
post #2 of 7 Old 07-15-2010, 11:35 AM
sherminator866
the 285s are going to be 11.2 inches wide and 33.8 tall the 305s if they are 75/17s will 12 inches wide and 35 inches tall according to a calc.
sherminator866 is offline
post #3 of 7 Old 07-15-2010, 12:35 PM
RowJ
Originally Posted by Leonidas View Post
.....I'm planning on running Mamba 17" x 8 wheels with BFG ATs either 285 75 R17s or 305s.......
The BFG A/T's are 285/70/17's. And they don't make a 305 A/T in 17". Sorry!
Can see sizes HERE
But 285's and 305's will fit on 8" wheels and are about the same height!
RJ
RowJ is offline
post #4 of 7 Old 07-15-2010, 02:53 PM Thread Starter
Leonidas
Junior Member
so no wear issues with the wider tires bowing? I heard that recently
Leonidas is offline
post #5 of 7 Old 07-15-2010, 02:56 PM
dcope17
not if you run the right air pressure.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #6 of 7 Old 07-15-2010, 03:08 PM
RowJ
Do the chaulk test!
Draw a line from side to side, across the tread. Drive 100 yds in a straight line and check the line. If chaulk still on the edges.... too much air.
RJ
RowJ is offline
post #7 of 7 Old 07-16-2010, 07:15 AM Thread Starter
Leonidas
Junior Member
That's a good idea. Thanks for the info
Leonidas is offline
tire , wheel , size , bolt pattern , width
Wheel and Tire Combo lpmorgan TJ Wrangler Technical Forum 3 04-09-2010 06:06 AM
Wheel & Tire Combo Jayme JK Wrangler Technical Forum 3 04-27-2007 08:28 AM
31x10.5x15 wheel tire combo on stock tire carrier? ADIDAS TJ Wrangler Technical Forum 13 06-24-2005 11:20 AM
Tj Wheel and tire combo rab3t TJ Wrangler Technical Forum 5 04-08-2005 04:39 PM
Help! Wheel/Tire combo... DaBurghBoy TJ Wrangler Technical Forum 4 09-26-2002 09:29 AM
