tire and wheel backspacing help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > tire and wheel backspacing help
USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4Eliminate Hood Flutter!!!Offset Tie Rod Kit From RuffStuff!
Unread 05-26-2012, 01:00 PM   #1
jeepguner
hi i put the zone 3 inch lift and am going to put on 33/1250s , ok at zone they say i need 3.5 inch back space. on a 8 inch wheel. ok so i am at the tire shop and looking at new wheels and the guy is giving me back spacing in mm so what would 3.5 be in mm. hope this makes some since
jeepguner is offline   Reply With Quote
Unread 05-26-2012, 01:08 PM   #2
terpsmandan
88.9 mm
terpsmandan is offline   Reply With Quote
Unread 05-26-2012, 01:10 PM   #3
jeepguner
is backspace the same as offset
Unread 05-26-2012, 01:18 PM   #4
terpsmandan
No. Backspacing is the measurement from the inside of the rim to where the wheel mounts to the hub. Offset is the measurement from the center of the wheel to the hub.
Unread 05-26-2012, 01:23 PM   #5
jeepguner
does 3.5 back space sound ok for a 3 inch lift 33/1250, and cant i go to a shop and say i need a wheel with this back space
Unread 05-26-2012, 01:25 PM   #6
biffgnar
biffgnar's Avatar
That's maybe a little on the low side, but if you like the wheels and don't mind a wide stance go for it. Shouldn't have any trouble with rubbing as long as axle (roughly) centered.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote
Unread 05-26-2012, 01:29 PM   #7
jeepguner
dont like the wide stance but dont want any rubbing issues . what would be best buying new wheels and tires
Unread 05-26-2012, 01:29 PM   #8
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Most aftermarket wheels for jeeps have 3.75" backspacing,so 3.5" is fine.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
TheBoogieman is offline   Reply With Quote
Unread 05-26-2012, 01:34 PM   #9
jeepguner
hey boogieman talked to you before and was going to get the spacers and keep my canyons. the shop said i will have issues with the spacers and they wont put the tires on the jeep have you had any issues with the spacers
Unread 05-26-2012, 01:40 PM   #10
Jeepin72
Is it the weekend yet?
Jeepin72's Avatar
I have run spacers for several years with no issues. Use loctite on the spacers lugs. The collective knowledge says that you will burn up bearings faster with spacers, but it hasn't happened to me yet.
I have never heard of someone refusing to work on a vehicle with spacers. Maybe its a vehicle inspection issue there in CA?
Jeepin72's Build Thread
Jeepin72 is offline   Reply With Quote
Unread 05-26-2012, 01:48 PM   #11
jeepguner
they will mount the tires for me but i have to put them on the jeep
Unread 05-26-2012, 02:15 PM   #12
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
No more so than a rim with equivalent back space...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote
Unread 05-26-2012, 02:22 PM   #13
jeepguner
if i put 1.50 inch spacers on with 33/1250s will they stick out to far
Unread 05-26-2012, 02:25 PM   #14
biffgnar
biffgnar's Avatar
Spacers with what wheels?
Unread 05-26-2012, 03:26 PM   #15
jeepguner
stock canyons
