Tire squealing while driving after lifting - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Tire squealing while driving after lifting
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread 05-27-2014, 04:32 PM   #1
Waltmackenzie
Hey all! I did a cursory search and didn't find many questions like mine so here I am. I just lifted my 2006 TJ Sport this weekend. Put a 4" lift on. Replaced front lower control arms (non adjustable, someone had them lying around and they seemed beefier than stock), installed adjustable front trackbar and relocated the rear. I'm not a big off road Jeeper yet. Maybe someday. Anyway, I now hear a sqealing noise coming from my front tires when I hit a bump or make a semi-sharp turn. It makes the same noise that you would hear on certain very smooth parking lots when you're turning. It's tire sqeek is the best way I can describe it. It did not make this noise before I lifted it.
Any suggestions?
Thanks
Walt
Waltmackenzie is offline   Reply With Quote Quick reply to this message
Unread 05-27-2014, 04:33 PM   #2
thethirdeye
You need to get an alignment, it's your tires pulling against each other
You changed your geometry, now you gotta make it right, either learn to driveway align or take it to a shop
thethirdeye is offline   Reply With Quote Quick reply to this message
Unread 05-27-2014, 04:41 PM   #3
Waltmackenzie
Good point! I did perform a driveway alignment and got the tow in to 1/16" tow in. My lower control arms have the cam slot but a solid round washer was installed in the "horseshoe" shaped alignment tab on the control arm mount so right now it's sitting dead center in the cam slot. The steering wheel is off by a degree or two. Is there a part of the alignment that I'm missing?
I appreciate your help!
Walt
Unread 05-27-2014, 05:09 PM   #4
thethirdeye
You really should use a camwasher, since you aren't using adjustable arms, little nuances will cause bIg problems when it comes to suspensIon and steering geometry
Unread 05-27-2014, 05:37 PM   #5
Waltmackenzie
I looked for just cam washers but I couldn't find any. It's the entire kit of bolt, nut, and washer and it's priced from $40-$50. Maybe I should leave those as is for now and save my money for adjustable lower control arms. The Jeep came to me with full, round washers installed. Not sure if thats factory or if the previous owner had a lift installed .
Walt
Unread 05-27-2014, 05:39 PM   #6
thethirdeye
Go to the rough country website, I'm pretty sure they sell just the washers
Unread 05-27-2014, 05:41 PM   #7
thethirdeye
34.95, cam bolts from rough country
Unread 05-27-2014, 05:44 PM   #8
eastcoastcam
I got Zone cam bolts/washers/nuts (a pair of them) from our local Jeep shop for $20. Stealership wanted $35 for one...
eastcoastcam is offline   Reply With Quote Quick reply to this message
Unread 05-27-2014, 05:52 PM   #9
Waltmackenzie
Checked them out and the notes say for the rear upper control arms only. Not sure why the notes say that. I'll have to give them a call.
Thanks for the idea and reference!
Walt
Unread 05-27-2014, 06:14 PM   #10
WKdeuce
You're missing something if the wheels crooked...
If you're getting 33s soon per your profile, just keep trying yourself, see what you can make of it.
Not sure what all you did or didn't do, so here check this out:
http://www.4x4xplor.com/alignment.html
http://www.wranglerforum.com/f210/ba...ent-86996.html
If you want to go into more detail:
http://www.jeepforum.com/forum/f9/en...g-read-663777/
2011 5.7L WK2 | 5.3L TJ work in progress
Rust in Pieces Blue
JEEP FIEND CLUB
WKdeuce is online now   Reply With Quote Quick reply to this message
Unread 05-27-2014, 06:19 PM   #11
Waltmackenzie
I guess I meant that I just need to get in there and make my wheel a little straighter using the drag link. Not that there is a problem, just that I need to fine tune the steering wheel. I got all my info from the links you attached. Really great info there! Thanks!
Walt
Unread 05-28-2014, 12:25 AM   #12
robncar
Try the procedure in my sig below... it may help.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline   Reply With Quote Quick reply to this message
