tire size / rear end questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > tire size / rear end questions
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRubicon Express Suspensions from CCOR 706-207-4140Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955
Unread 09-15-2014, 10:43 PM   #1
zracin
when it is suggested that the axles are upgraded in order to go beyond 33 inch tires, is this to prevent damage to the underpowered axles or is it to maintain a certain level of performance/acceleration, or some other reason I can't fathom.
zracin is offline   Reply With Quote
Unread 09-16-2014, 04:24 AM   #2
trickydick
http://www.fourwheeler.com/how-to/tr...uck-axle-tech/
read this
trickydick is offline   Reply With Quote
Unread 09-16-2014, 11:24 AM   #3
zracin
Thankyou! Looks like its mainly for survivability of the axles offroad. I may cruise light dirt trails or run through the odd pre-construction foreclosed/abandoned subdivision site. But im nearly 100% on street driving. Obviously ill lose a little of my already sluggish 5th gear acceleration, but it sounds like I could go from 33s to 35s without worry. I wont be wheeling over heavy debris or rocks.
Unread 09-16-2014, 11:43 AM   #4
biffgnar
biffgnar's Avatar
Going to 35's is a big commitment. Read up.
And don't wheel illegally.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote
Unread 09-16-2014, 03:38 PM   #5
m44
If you are 100% on the street why do you need 35" tires?
2003 Tj sport daily driver with a bunch of mods
1998 wrangler rolled and being rebuilt with tons
m44 is online now   Reply With Quote
Unread 09-16-2014, 03:54 PM   #6
J03_TJ
J03_TJ's Avatar
Why do you care?
J03_TJ is offline   Reply With Quote
Unread 09-16-2014, 04:31 PM   #7
wwch99tj
Originally Posted by J03_TJ View Post
Why do you care?
↑ this
Sent from my Galaxy Note 2 using my thumb
wwch99tj is online now   Reply With Quote
Unread 09-16-2014, 04:38 PM   #8
Ironhead
people have snapped d35 axle shafts on the street pulling a u-turn or backing out of a driveway. they simply were not designed to handle that much leverage
Ironhead is online now   Reply With Quote
Unread 09-16-2014, 04:38 PM   #9
joe_jeep
What axle do u have?
What gear ratio u got?
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote
Unread 09-16-2014, 08:42 PM   #10
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
What transmission do you have?
Filling-in your profile helps others help you...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote
