Tire size help - JeepForum.com
post #1 of 33 Old 03-28-2013, 09:04 PM Thread Starter
Kamkid
Tire size help
I have an 02 tj, inline 6 with Dana 44 in the back and 30 or 35 in the front. I have a roughcountry 4" lift and I'm running 33x12.5, I also have flat fender flares which give me alot of clearance. Should I go to 35"s? I would not be adding any more lift. I'm okay with minor rubbing while off roading.
Kamkid is offline
post #2 of 33 Old 03-28-2013, 09:06 PM
tyvanwie
If you need to ask for permission, no, you shouldn't go to 35s. Most people go to 35s because they need them for their terrain. And you shouldn't have rubbing with and tire size if you set up your rig properly. And it's a Dana 30 front, 35s are only rear.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #3 of 33 Old 03-28-2013, 09:09 PM Thread Starter
Kamkid
Oh and I know there are alot of threads with this info but I'm at work and the app is really bad on my phone. The best I could do was start a thread
Kamkid is offline
post #4 of 33 Old 03-28-2013, 09:10 PM Thread Starter
Kamkid
I have 44 in the rear though, atleast that's what the tag states. I'm basically asking it its possible without causing damage
Kamkid is offline
post #5 of 33 Old 03-28-2013, 09:14 PM
tyvanwie
What about the front axle? Brakes? Gears? Bumpstops?
tyvanwie is offline
post #6 of 33 Old 03-28-2013, 09:15 PM
Coop02x
Fill in your profile. You are probably going to want to consider re-gearing for the 35s if you still have stock gears.
Coop
Coop02x is offline
post #7 of 33 Old 03-28-2013, 09:15 PM Thread Starter
Kamkid
Oh sorry misunderstood, so yes it is Dana 30 in the front
Kamkid is offline
post #8 of 33 Old 03-28-2013, 09:16 PM Thread Starter
Kamkid
I'm not sure what gearing I have, I thought it was 3.73 but my buddy has an identical jeep to mine and my is a little more balsy.
Kamkid is offline
post #9 of 33 Old 03-28-2013, 09:18 PM
Coop02x
Sounds like you have enough clearance (so long as your bump stops are setup correctly). A 1"-1.25" BL would also help alleviate any clearance concerns if you don't already have one. Again, fill in your profile!
Coop
Coop02x is offline
post #10 of 33 Old 03-28-2013, 09:18 PM
tyvanwie
And you're sure you have a 44?
tyvanwie is offline
post #11 of 33 Old 03-28-2013, 09:19 PM Thread Starter
Kamkid
I would be keeping the same axel, possibly a regear though, 4.10?
Kamkid is offline
post #12 of 33 Old 03-28-2013, 09:20 PM Thread Starter
Kamkid
Yup
Kamkid is offline
post #13 of 33 Old 03-28-2013, 09:24 PM Thread Starter
Kamkid
Haha what would you like to see in my profile? I don't think I can do much from my phone
Kamkid is offline
post #14 of 33 Old 03-28-2013, 09:33 PM Thread Starter
Kamkid
Ill be honest, this may seem foolish but I'd like to do 35" without spending much cash. I don't really want to do a BL, and I'm not sure about my bumpstops, I'm still learning with alot of this.
Kamkid is offline
post #15 of 33 Old 03-28-2013, 09:34 PM
tyvanwie
Then no. Don't get 35s.
tyvanwie is offline
