Tire Size Help - JeepForum.com
post #1 of 4 Old 08-12-2011, 07:03 PM Thread Starter
TJjason
Tire Size Help
Hey all
So right now I have the stock wheels that came with my jeep but I am looking at purchasing some 15x10 rims and running 33" Duratracs.
Just have two questions:
1. Will the 33's fit with a 2" budget boost and 4" offset in the wheels?
2. Are the Duratracs any good?
Thanks for the help.
TJjason is offline
post #2 of 4 Old 08-12-2011, 08:51 PM
dlysle
15x10 wheels may be pushing it, i know a lot of people run them that way but i would stay with a 15x8, especially if you are going to use it offroad and air down, an 8 inch rim will hold the bead better at lower pressure.
as for the 2" BB, some will tell you it won't work, but i did it. i didn't wheel it that way, but the only time i got rubbing was when my sway bar shifts to the driverside a little and then when i make tight right turns it rubs. after a few months i swapped out the front spacer for V8 ZJ springs (2.25" of lift vs 1.75 fron the spacer), i still have the BB spacer in the rear. i like how it rides and looks, and i was able to do it without spending $800 on a full blown lift kit.
first pic is with the BB only, second is with the ZJ springs. BTW, those are the stock 15x8 ravine wheels with a 1.25" wheel spacer.
'You may not realize it when it happens, but a kick in the teeth may be the best thing in the world for you.' - Walt Disney, Animator, Film Producer
'four wheel drive only allows you to get stuck in more inaccessible places' - George Noll
dlysle is offline
post #3 of 4 Old 08-12-2011, 10:01 PM
wkrowe65
I agree. You want 15x8 wheels, then you will not need wheel spacers.
wkrowe65 is offline
post #4 of 4 Old 08-12-2011, 10:21 PM
stuntjumper
Duratrac's are awesome, too bad they don't make 'em in 35's. Great snow tire and great mix for wheeling and regular road driving. If you are looking to wheel around here with 33's you'll want something more than a 2" BB. At least put a 1.25" BL with it, but I'd go at least 2.5" SL as well. And like said above, go 15x8 instead of 15x10.
_____________________________________________
'98 - 4.0 - HP30 Front, 8.8 Rear, 4.88 -1.25" BL, Brown Dog 1" MML, 3.5" RE springs and crappy shocks - 33" Goodyear Duratrac on Crager soft 8's 15x8 - Toys By Troy front roll cage and custom welded rear roll cage addition.
stuntjumper is offline
duratrac , goodyear , lift and tire combination
Just lifted. now figuring out tire size Tire size? usnavydoc TJ Wrangler Technical Forum 8 05-04-2011 09:58 AM
A couple of tire model and size questions (what size with stock gears) GraysonJeep JK Wrangler Technical Forum 17 07-22-2010 02:36 PM
Tire Size and Wheel Size Guess user77877 JK Wrangler Technical Forum 4 06-28-2009 11:22 AM
stock tire size vs bigger tire size jtaylor83 TJ Wrangler Technical Forum 4 11-14-2008 08:20 AM
Spare Tire Size vs Tire Size Roadstar TJ Wrangler Technical Forum 2 02-20-2003 11:14 AM
