-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Tire Size Help (http://www.jeepforum.com/forum/f9/tire-size-help-1252145/)
TJjason 08-12-2011 07:03 PM
Tire Size Help
Hey all
So right now I have the stock wheels that came with my jeep but I am looking at purchasing some 15x10 rims and running 33" Duratracs.
Just have two questions:
1. Will the 33's fit with a 2" budget boost and 4" offset in the wheels?
2. Are the Duratracs any good?
Thanks for the help.
dlysle 08-12-2011 08:51 PM
2 Attachment(s)
15x10 wheels may be pushing it, i know a lot of people run them that way but i would stay with a 15x8, especially if you are going to use it offroad and air down, an 8 inch rim will hold the bead better at lower pressure.
as for the 2" BB, some will tell you it won't work, but i did it. i didn't wheel it that way, but the only time i got rubbing was when my sway bar shifts to the driverside a little and then when i make tight right turns it rubs. after a few months i swapped out the front spacer for V8 ZJ springs (2.25" of lift vs 1.75 fron the spacer), i still have the BB spacer in the rear. i like how it rides and looks, and i was able to do it without spending $800 on a full blown lift kit.
first pic is with the BB only, second is with the ZJ springs. BTW, those are the stock 15x8 ravine wheels with a 1.25" wheel spacer.
wkrowe65 08-12-2011 10:01 PM
I agree. You want 15x8 wheels, then you will not need wheel spacers.
stuntjumper 08-12-2011 10:21 PM
Duratrac's are awesome, too bad they don't make 'em in 35's. Great snow tire and great mix for wheeling and regular road driving. If you are looking to wheel around here with 33's you'll want something more than a 2" BB. At least put a 1.25" BL with it, but I'd go at least 2.5" SL as well. And like said above, go 15x8 instead of 15x10.
The time now is 04:08 AM.
