Tire size with a 4 cylinder? - JeepForum.com
 6Likes
post #1 of 51 Old 11-03-2011, 09:38 AM Thread Starter
98Tjboy
I have read up on many different threads on max tire size a 4 cylinder can handle and some say of regeared ones wearing 35's. What is the max size you can wear without having to replace the axle?
98Tjboy is offline
post #2 of 51 Old 11-03-2011, 10:13 AM
geiman
Has nothing to do with being a 4 cylinder; the 4 cylinder will only want to make you regear even more. The 4 cylinder has the same D35 rear axle as many other models, and as such the same rules apply. Only difference may be that since you've got a bit less power you may be less prone to snap an axle as opposed to someone with a 4.0 or larger engine.
z5000 likes this.
geiman is offline
post #3 of 51 Old 11-03-2011, 10:29 AM
troy.j
488 is as deep as you can go with the stock axles. Your 4 banger will be happy with 33s and those gears. If you want larger I recommend changing axles so you can go deeper with the gears. With a 4 and 33's I doubt you will break the D35.
Jerry Bransford likes this.
99 tj, 00 wj, 95 yj
...ask those who have bled of the cost of freedom and honor those who gave that others may have what we take for granted...
troy.j is offline
post #4 of 51 Old 11-03-2011, 10:31 AM
Tyler99TJ
Don't go any larger than 31's on a 4 cyl TJ. If you want to go taller you will have to regear the axles ~$1000, then most likely you will need a Slip yoke eliminator for the lift height ~800 and it starts to get really expensive really fast. So unless you are wanting to spend about $3000 to have a Jeep that will run tall tires well, keep it on 31's.
After saying that, I am running a street TJ on 33's with 4.56 gears and it does alright on the road, and I have a trail TJ 4 cyl with 4.88 gears and 35" tires that needs a 4 to 1 transfer case.
Tyler99TJ is offline
post #5 of 51 Old 11-03-2011, 11:15 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
33x10.50 tires are ok for a 4 banger and flat Florida.
TheBoogieman is offline
post #6 of 51 Old 11-03-2011, 11:18 AM
Dextreme
Personally I agree with this. I know lots of people do go bigger and are willing the throw the money at it to do it....and then throw money at to continually chase the weakest link.
I just think a great combo for a 4cyl TJ Daily Driver for its stock gearing is 31's with a 2" lift (BB or Spring)...but I know that was not your question.
Dextreme is offline
post #7 of 51 Old 11-03-2011, 11:34 AM
TheBoogieman
How many 4 bangers have you had and wheeled?
post #8 of 51 Old 11-03-2011, 12:03 PM
Tyler99TJ
This is what I run on my street TJ. They helped a little when I ran stock gears. When I bumped to 4.56 gears it helped much more. I like to drive faster than the speed limit and 33's and 4.88's top out around 70 mph.
I should also add that when I was in college I drive over the App mountians back and forth 300 miles on 33's with 4.10 gears, so it can be down, its just not enjoyable to drive on the highway.
post #9 of 51 Old 11-03-2011, 12:24 PM
TheBoogieman
That's just sad. Every Jeep I've ever owned with 35's and 3.73 gears could easily hit 85 mph with auto or 5 and 6 speed stick.
post #10 of 51 Old 11-03-2011, 12:26 PM
TheBoogieman
Mountains kill mileage.My GF has a son going WVU and they suck.
post #11 of 51 Old 11-03-2011, 12:29 PM
JeepGuy813
Ive had my jeep ( 4 cyl ) around 70mph with 33x10.5 and stock 4.10's. and personally thats fast enough in a jeep for me. I think 85+ would be kinda scary in that small little box
1995 Jeep Wrangler Yj = SOLD
1999 Jeep Grand Cherokee WJ = SOLD TO PARENTS
1997 Jeep Wrangler Tj = SOLD and missed alot
JeepGuy813 is offline
post #12 of 51 Old 11-03-2011, 12:37 PM
Bordr329
33 x12.5s here with 4:10 gears..... It aint bad. It aint good. Crawls a little faster.than I want and can speed if.i want to...
Bordr329 is offline
post #13 of 51 Old 11-03-2011, 01:09 PM Thread Starter
98Tjboy
Whats your max speed Bordr?
98Tjboy is offline
post #14 of 51 Old 11-03-2011, 02:44 PM
Tyler99TJ
I have had my TJ with 4.10's up to 90 mph going downhill, its the 50 mph going up the hill that sucks.
With the 4.56's I will go 75-80 down hill and then go down to about 65 going up hill.
It all depends on what you can live with.
post #15 of 51 Old 11-03-2011, 03:01 PM Thread Starter
98Tjboy
So with your size tires, would i be better off at 4.56 or 4.88?
98Tjboy is offline
Just lifted. now figuring out tire size Tire size? usnavydoc TJ Wrangler Technical Forum 8 05-04-2011 09:58 AM
A couple of tire model and size questions (what size with stock gears) GraysonJeep JK Wrangler Technical Forum 17 07-22-2010 02:36 PM
Tire Size on a 4-Cylinder muddy8jeep8 TJ Wrangler Technical Forum 17 05-17-2009 01:39 PM
stock tire size vs bigger tire size jtaylor83 TJ Wrangler Technical Forum 4 11-14-2008 08:20 AM
Size of Gas Tank in 92 Jeep YJ 4 Cylinder kaze0103 YJ Wrangler Technical Forum 1 08-23-2008 06:31 PM
