Quantcast Tire Shop Won't Align My Jeep? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Tire Shop Won't Align My Jeep?
Old 05-18-2009, 05:34 PM   #1
UFMech
Hello,
I have a question related to tire and wheel alignment. I recently had a 2" budget boost installed and new skyjacker hydro shocks as well. After the install I took my Jeep to Firestone and they said they couldn't do an alignment on my Jeep because my tire beads were sticking out a bit from my rims. I have the BFG A/T 31"x10.5" tires on a 15x8" rim...
Has anyone had this problem before? If so how did you get your tires / wheels aligned? I've read some posts on adjusting the toe-in yourself but am not sure this is the best option.
Any help is appreciated!
Thanks,
Jason
UFMech is offline   Reply With Quote
Old 05-18-2009, 05:39 PM   #2
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
I would take it to a different shop, and have it done, or do it yourself.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 05-18-2009, 05:41 PM   #3
mcg311TJ
What a PITA. Take it to a mom and pop garage ( not some shady place, Someone you can trust ). Goodyear, Firestone, etc. just wont do it because of insurance issues. Good luck
mcg311TJ is offline   Reply With Quote
Old 05-18-2009, 05:41 PM   #4
Aldo258
Im an Alignment tech. at Goodyear tire center and sometimes we get cars in there with no rim lip, therefore forcing you to use a special adapter on the alignment head to squeeze in between the rim and tire. Although it is very tough to do sometimes ( especially with those bfg at's) it can be done. Sounds to me like someone is lazy, i'd try a different shop.
Aldo258 is offline   Reply With Quote
Old 05-18-2009, 05:43 PM   #5
mcg311TJ
Or what he said^^^^^^^^
Old 05-18-2009, 05:54 PM   #6
RnEmOvr
Never Forget
RnEmOvr's Avatar
http://www.jeepforum.com/forum/f9/end-all-all-tj-alignment-thread-long-read-663777/?highlight=alignment
do it yourself
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 05-18-2009, 06:31 PM   #7
willydigger
Thanks for the Upgrade!
willydigger's Avatar
I had the same problem. Took it to Merchant's and they didn't have the right clamp. They told me to go to an NTB five minutes up the road. It was a bigger shop with the right clamps. NTB did a great job. The tire balance and alignment cured my death wobble twice.
WHODEY
willydigger is offline   Reply With Quote
Old 05-18-2009, 08:39 PM   #8
little4x4
i do them all the time at our body shop... they are a PITA but have not had one that i couldn't do. go to a shop willing to do work and you'll get a better job every time.
00 tj Old man emu susp. 1" bl 285x75 Procomp Xterrain's warn x8000i in an ARB fnt bumper custom rear with tire carrier, high lift jack locked in fnt and LSD in the rear, sway bar disconnect, steering engine and fuel tank skids, 4L engine, 5 speed tranny, 4.10s and a few other things.
little4x4 is offline   Reply With Quote
Old 05-18-2009, 08:48 PM   #9
Aldo258
I definitely agree, its really not that hard to take a little extra time to get it done right. Ive even sometimes had to have a co-worker push while i tightened the alignment head down, not really a big deal if you have the right adapters.
Old 05-18-2009, 08:48 PM   #10
UFMech
I have read several how-to's on doing the toe-in alignment myself... should I just follow those guidelines and adjust the toe-in then the steering wheel, and call it a day? Seems fairly simple unless I'm missing something... let me know.
Thanks.
Old 05-18-2009, 09:19 PM   #11
Unlimited04
Unlimited04's Avatar
Originally Posted by UFMech View Post
Hello,
Thanks,
Jason
I've got those same tires on 15x8 stock Ravine wheels and Firestone did my alignment without issue. Tire beads didn't effect the alignment at all. Your shop doesn't know wtf they're doing, find someplace else.
Unlimited04 is offline   Reply With Quote
Old 05-18-2009, 09:24 PM   #12
mudb8
want it rite or rite now?
mudb8's Avatar
that's the dumbest excuse I ever heard...
you don't need a special stinkin tool... just push em in.. you can also set the bottom and turn the clamp down past the lip, push and use the prongs on the tool to lift up the bead while pushing em in to hook the rim..
I do em all the time... yes it takes an extra 20 seconds.. big deal.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 05-18-2009, 09:32 PM   #13
Jeepster83
when i had mine aligned - 33x10.50 BFG AT's - i was in and out within a half hour. go somewhere else.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Currently seeking employment in the automotive field or fabrication. PM me for resume and list of qualifications.
Jeepster83 is offline   Reply With Quote
Old 05-18-2009, 10:55 PM   #14
TexanTJ
it is a wast of money to pay anyone to align a wrangler for you. just get a socket set and a tape measurer and do it yourself.
follow the writeup at 4x4xplor.com
2005 Bright Silver Metallic X D30/8.8 lsd, 2.5" Skycrapper springs, TNT Phantoms front/ Genright hi-clear Rear. D30 Lockright, LOD Rear Swingout, hardtop, hard and soft upper doors, Bestop bikini/jammer/duster, Bestop SuperTop, HacknTap, 8000lb Gorilla, Magnaflow, Moabs. 285/75R16s Firestone Destination ATs, Smittybilt XRC Stinger
2006 GTO M6- Under 20k miles... Garage Queen
TexanTJ is offline   Reply With Quote
Old 05-18-2009, 11:20 PM   #15
ArchStanton
I recently purchased the same tires and had the alignment done. Pep Boys didn't have any problem. I too have the 15x8 Ravine rims. Next, I'm planning on getting the Skyjacker Hydro Softrides and installing a BB. How do you like your Hydros? Which BB did you install? I'm looking for a quality American-made set of spacers. Good luck.
ArchStanton is offline   Reply With Quote
Glock Forum
