Tire Rubbing on Frame After Frame Swap - JeepForum.com
post #1 of 5 Old 10-18-2011, 11:32 AM Thread Starter
nickrad8
I recently swapped the frame on my 99 sahara with the frame from a 4 cyl 05 tj. prior to the swap, my rear tires had plenty of clearance. after the swap, my right rear tire seems to be rubbing up against the part of the frame that holds the coil spring in place. the jeep is lifted 2.5" via bigger springs. does anyone know what could be causing this to happen? and if so, any solutions to the problem?
nickrad8 is offline
post #2 of 5 Old 10-18-2011, 11:44 AM
hustler905
Have you done any investigating in the rear track bar area?
hustler905 is offline
post #3 of 5 Old 10-18-2011, 11:49 AM
Necko2529
You need to center your axle
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #4 of 5 Old 10-18-2011, 11:53 AM Thread Starter
nickrad8
i havent looked at the rear track bar area yet. i just assumed it was fine because i didnt change anything but the frame. everything was fine prior to the swap. what should i look for in the track bar area?
how do i go about centering the axle?
nickrad8 is offline
post #5 of 5 Old 10-18-2011, 09:45 PM Thread Starter
nickrad8
for some reason, on my old frame the part of the suspension that holds the coil springs in place was shaved down either in the factory or by the previous owner to fit larger tires. the new frame was not shaved down. the rear diff is centered. the wheel spacers are coming later this week to fix the issue
nickrad8 is offline
frame swap , lift , rear end , rub , tire rub
rubbing sway bar on frame???? armyman89 TJ Wrangler Technical Forum 6 04-24-2011 08:32 PM
YJ Frame differences? Can I frame swap any platform Nate M YJ Wrangler Technical Forum 5 10-26-2010 09:17 AM
Sway bar links rubbing frame doubleup TJ Wrangler Technical Forum 14 08-17-2010 08:47 AM
swap wrangler frame with cj7 frame midgetdog YJ Wrangler Technical Forum 7 04-15-2009 10:58 AM
Sway bar is rubbing frame jeepermeo2 TJ Wrangler Technical Forum 3 03-04-2007 07:06 PM
