Tire pressure for 31-10.5-15 - JeepForum.com
post #1 of 7 Old 04-09-2004, 06:20 AM Thread Starter
customjeeptj
What would be the best tire pressure for that size tires.
customjeeptj is offline
post #2 of 7 Old 04-09-2004, 10:05 AM
powerstroke01
powerstroke01's Avatar
2005 WK
I would like to know too..
Jeepers do it in the mud. ;)
powerstroke01 is offline
post #3 of 7 Old 04-09-2004, 10:31 AM
cpleasant
cpleasant's Avatar
Would it depend on Rim size, i.e. 15x7, 15x8?
cpleasant is offline
post #4 of 7 Old 04-09-2004, 11:38 AM
DirtyRedTJ
DirtyRedTJ's Avatar
On a 15 x 8 rim, I would run about 30 psi street and 15 psi off road. For a 15 x 7, I would drop the street pressure a little.
If you do some searching you can find a link to the chalk test, which is really the best way to set you psi.
You Gotta Hit It Harder Than That!
1998 SE, 4 Gerbils , 5 speed,
D30 Front, Diff Guards, QD's,
3" Black Diamond springs, Rough Country LCAs,
Pro Comp es3000's, 2" bl, 8,000lb winch,
TB spacer, K&N, Electric Fan, hand throttle,
CB, Seat covers, chopped bumper,
33 x 12.50 Truxus MTs, AR wheels,
Rocker guards, Lights, High Lift ...
[COLOR=darkred]Certain Death Jeep Club Member #2[ /COLOR]
2002 WJ 31x11x16 Thornbirds, Westin Safari Bar
DirtyRedTJ is offline
post #5 of 7 Old 04-09-2004, 06:33 PM
doorocks
doorocks's Avatar
I run my 31/10.5 on 15x8 at 26-28 psi. Ride great. You take the weight of your TJ and divide the weight equally in pressure on all 4 tires.
ex: TJ weighs 4000, that's 1000 per tire. Your tire at 50 psi will sustain 2000 pounds of weight(max) Since your tires are only holding 1000, you half the inflation maximum. 25psi. plus change for a little extra. By plus change I mean 2 pounds.
This is a general equation but fairly accurate. Jerry B. has a better explanation that I do, but it is pretty similar.
Steve
LIFE IS TOUGH ENOUGH ALREADY, IT'S EVEN TOUGHER WHEN YOU'RE STUPID.
RE 3.5 and all kinds of other relevant goodies, you know winch and stuff.
Life is like walking into the No Chance Bar full of Future Darwin Stories........
More mods than a hillbilly's set of teeth..
doorocks is offline
post #6 of 7 Old 04-09-2004, 07:04 PM
el golfo
Steve
great responce,i do the same,but when i am on the beach i drop it to 11psi with no problems,while in town i run 28 psi with no problems after 25k
2000 tj 31's,kyb shocks,garvin roof rack,orf sport cage,set up for sandunes and beach running
el golfo is offline
post #7 of 7 Old 04-10-2004, 07:14 PM
powerstroke01
2005 WK
So 28-30 then huh????????????????
31" BFG A/T Tire pressure and Spare tire carrier Questions.. jeep2029 TJ Wrangler Technical Forum 14 08-20-2009 07:31 PM
Tire pressure jay-h Wrangler General Discussion 2 07-05-2009 09:37 AM
Tire Pressure duncur TJ Wrangler Technical Forum 7 10-19-2008 07:34 AM
Tire Pressure newjob1975 JK Wrangler Technical Forum 4 04-13-2007 04:49 PM
Tire Air Pressure ?? clarky711 YJ Wrangler Technical Forum 3 03-19-2003 10:17 PM
