Tire Dilemma - JeepForum.com
post #1 of 5 Old 08-29-2005, 03:02 PM Thread Starter
Kentuckyarms
Kentuckyarms's Avatar
Tire Dilemma
Here is the deal..... I have a 1" BL on right now. I have a REBB sitting in the garage ready to go on.
In order to run 32X11.50X15's I will need to purchase wheel spacers. Wheel spacers will be about $62.00 a wheel. I want to keep my stock rims.
I have seen guys with 33X10.50X15's with no wheel spacers. I can get tires this size for around $42.00 a tire more. This would save $20.00 a wheel and $60.00 on the whole project. Can I run 33X10.50X15's with just a 1"BL and a REBB?
2012 JK Sport
3.6L
5 Speed Auto
RE 2" Budget Boost
285/75/16 MT
Kentuckyarms is offline
post #2 of 5 Old 08-29-2005, 03:32 PM
JoonHoss
2011 JK Wrangler
yep!
alot of guys run that set-up, and are very happy.
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #3 of 5 Old 08-29-2005, 04:12 PM
mjkolb02tj
Stupid is as Stupid does
mjkolb02tj's Avatar
I am not running 33's but rather 31" X 10.5" on my stock rims. The height of the tire should not be a problem since you have a 1"bl and a 2" bb but where you may run into a problem is in the tire width. You may notice the tires rubbing when you are full steer. That can be solved by adjusting you steer stops which is what I did and I believe many others also have done it. Here is a link to a good write-up. http://www.4x4xplor.com/steerstop.html
Hope that helps.
Mike
Originally Posted by martinsburgjeep
Don't knock low standards, if your dad didn't have them you wouldn't be here to argue with us.
Originally Posted by BlueTeeJay
That'd suck. You must not go topless as much as I do.
SAVE PARAGON! Visit
to get more information.
mjkolb02tj is offline
post #4 of 5 Old 08-29-2005, 04:28 PM
Rocky529
Rocky529's Avatar
Yes you can run that set-up. Keep in mind you will get some rubbing especially disco'd with 33s. While you don't need wheel spacers with 10.5" tires, you probably will need to add a couple of washers on the steering stops to prevent rubbing. Afterall, stock is 9.5" so one inch bigger could create minor rubbing without the proper backspacing.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #5 of 5 Old 08-29-2005, 09:54 PM
pismo61
pismo61's Avatar
2015 JK Wrangler
No rubbing with 32x11.5s with ravine wheels.However the rear spring perches come with in a 1/2 inch, still no rubbing yet. I have no washers in front on the turn stops and still no rubbing on full turns.Again I have not don these monuvers on full flex.
2015 Red 2 Door(half) 6sp.
pismo61 is offline
My Tire Dilemma.. FourbyFour TJ Wrangler Technical Forum 11 08-02-2009 04:55 PM
Tire dilemma tecumsa Wrangler General Discussion 5 07-20-2009 01:57 AM
Tire dilemma. 33's on a 98 TJ Sport? dbdraggin TJ Wrangler Technical Forum 14 07-28-2008 08:24 PM
Lift/Rack/Tire Carrier Dilemma MrKleen TJ Wrangler Technical Forum 4 04-25-2007 09:21 AM
lift/tire dilemma Varsity Tyler YJ Wrangler Technical Forum 9 09-22-2004 07:54 PM
