Tire Carrier Third Tail Light Write-up
| Truck-Lite's New LED Headlamp Series | NEW! Poison Spyder RockBrawler BFH Bumpers! | Poison Spyder BFH Rear Bumpers |
#1 | |
Finally got my Lod Tire Carrier - install was very straight forward.
I looked at options to re-locate the third brake light and decided to make my own after seeing what a guy in our local Jeep Club (MJ'sTJ). I used a 2 1/2 inch round LED from AutoZone, and a center cap from my spare wheel, but any center cap like the one shown would probably work. ![]() ![]() I cut out the center of the cap so that the light would fit over the end - the rubber grommet fit nicely. I connected some handy-dandy speaker wire that I had laying around and ran it out through the side of the base of the wheel cap. ![]() ![]() I removed the plastic tailgate hinge cover and spliced the wires there. I enclosed the speaker wire in a loom and zip tied it to the carrier. ![]() ![]() I positioned the center cap, the mounted the tire. ![]() ![]() Pretty cool at night: ![]() This whole project took me less than an hour, and cost around $20. Click Here for the pictures Again, I'd like to give credit to MJ'sTJ at La4x4.com for the idea.
2005 Wrangler Sport - 4.0L 6 speed Rusty's 3" Lift, 33x12.5 Trxus MT's, JKS 1.25" BL, JKS BMML, Jeeperman Skidz Jeeperman Bumper/Pre-runner Bar, Warn Winch, Front Aussie Locker Last edited by wenkebach; 01-03-2008 at 04:34 PM.. |
#2 | |
The pics are not working for me???? ?
05 [B]Black[/B] TJ Rubicon 2" Spring lift, Hella 500's on the windshield, SRC front bumper, SRC rear bumper w/ tire carrier, SRC rocker guards/steps, Mile Marker PE8000 winch |
#3 | ||
Disgruntled Jeepforum'er
Location: NY/NJ/PA Tri-State Middletown NY 10941, New York
-Ryan Google Voice (or the number Grape calls when drunk): 845-476-8182 Quote:
#4 |
Sorry guys - I fixed the links.
2005 Wrangler Sport - 4.0L 6 speed Rusty's 3" Lift, 33x12.5 Trxus MT's, JKS 1.25" BL, JKS BMML, Jeeperman Skidz Jeeperman Bumper/Pre-runner Bar, Warn Winch, Front Aussie Locker |
#5 |
they still dont work..........
DAILY DRIVER 1996 Cherokee Classic 4.0HO 5-SPEED! | 16x8 Rucicon Moabs | lowered 1" | clear corners | silverstars | custom waggy taillights | custom intake | Aem TB spacer | Dynomax cat-back | Bored TB | FirePower Ignition Kit CLASSIC TOY 1968 Chevy C-10 short bed Chevy 350 crate motor | 4-speed | fully restored | Lowered | 20" Centerline Daggers.. wayyy too much to list Project 1988 Pontiac Trans Am GTA 350 TPI | WS6 | 48k original miles | Flame Red Metallic SOLD: 94 cherokee | Lifted | Locked SOLD: 97 TJ | 33's | 4.56's | :( Searching for an Ls-1 Rx-7 project.... |
#6 | |
I'll get it fixed - hang on.
#7 |
Ok - Hope this works now
#8 |
I see pictures. Nice job too.
#9 |
nice job
#10 |
yep works now. That looks like a nice little project that i'll have to do when it gets warm out.. I'll remember this..
#11 | ||
Looks good. I mounted mine directly to the carrier and drilled a couple holes to run the wire through the carrier.
99 Sport I6 Auto | 4" Currie/ProComp/Skyjacker| 35" BFG KM2's on black steel rims | LoD xtreme duty rear bumper/tire carrier | Rokmen Mercenary rockers | Quote:
#12 |
That looks great - I didn't have a drill strong enough to drill thru the carrier, otherwise, I would have done it like yours too.
Looks awesome!
#13 |
Nice.....
Good job!
#14 |
So does the wire go between that tire carrier plate and the wheel itself? I tried something similar before I got my Jeeperman carrier and after a while, the wheel cut into the wire and shorted it out.
You may want to slightly revise the metal plate so the wire runs through a hole instead of pinching between the plate and wheel, like you showed here: ![]()
-Paul Green Jeep Member #155 Low Output 4 Cylinder Jeep Member #35 Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it. |
#15 |
Actually - for whatever reason - there is a nice 1/4" gap that the wire runs through. I think it is because I have 33" tire on an 8" rim that "balloons" the tire a bit.
In other words, once the tire is snugged down against the tailgate isolators, there is still space between the rim and the carrier - about 1/4" I know it may be different for everyone; in fact, here is a variation from MJ'sTJ. He ran his wire through the wheel and into the side of the cap. This is ok, but in order to take the tire off, he has to disconnect the tail light/center cap. Minor inconvenience. Another option would be to place some galvanized washers over the lug bolts and create a slight gap where the wire would run.
2005 Wrangler Sport - 4.0L 6 speed Rusty's 3" Lift, 33x12.5 Trxus MT's, JKS 1.25" BL, JKS BMML, Jeeperman Skidz Jeeperman Bumper/Pre-runner Bar, Warn Winch, Front Aussie Locker Last edited by wenkebach; 01-04-2008 at 10:17 AM.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
