Tire Carrier ?? - JeepForum.com
post #1 of 15 Old 03-18-2005, 06:59 AM Thread Starter
04TJFan
Tire Carrier ??
I just had some new 31x12.5 Pro Comp ATs put on the Jeep and I'm wondering if the stock tire carrier can carry the weight of the new tire and steel wheel without damaging the rear door?? The tire weighs about 45 pounds and the Crager 397 is about 22-25 lbs. Do you thing it will be alright? Thanx for the help
Scott
Black Jeep Club Member #2004
Jarhead Jeep Club Member #4
Rubicon Express 2" Budget Boost
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Bushwacker Fender Flares
04TJFan is offline
post #2 of 15 Old 03-18-2005, 08:47 AM
GzrGlide
GzrGlide's Avatar
If you do a search you'll find that the general consensus is that the 31 will be fine.
Most people say that once you get up to 33's that the stock carrier needs to be replaced.
Mike
<<< ya know ya want to!
98 TJ SE
RE 4.5SF with 3.5 springs & Tera QDFTs
Super 35 & Detroit in back w/4.88s
33x10.5 BFG KM2's
Cobra 75WXST w/4' Wilson Antenna
Warn M8000
(1) Rubber Ducky
GzrGlide is offline
post #3 of 15 Old 03-18-2005, 08:50 AM
digitalcox
digitalcox's Avatar
yeah, I just mounted a 32x11.50 tire on a 15x8 crager wheel on my stock tire carrier the other day.
I raised the thrid brake like an inch and also extended my rubber isolater that are attached to the tailgate so that it touches the spare to prevent it from moving back and forth much.
I read about some people being perfectly fine running bigger tires (up to 33") on a stock carrier but yet I also hear horror stories of others having them crack or bending.
Have a good one,
Justin
digitalcox is offline
post #4 of 15 Old 03-18-2005, 08:57 AM
b3x
b3x's Avatar
I put my 33" on the stock carrier, i have yet to move the light ... it is still partially visible over the tire.
While, I do intend on getting a bumper mounted tire swing in the future, i have yet to notice any ill effects of the larger tire on the stock mount. I can imagine that keeping the tailgate open for extended periods of time would lead to problems, but for now the stock mounts apear to hold the additional weight just fine.
b3x is offline
post #5 of 15 Old 03-18-2005, 09:00 AM
FlyersFan2009
FlyersFan2009's Avatar
If you don't wheel your Jeep you may not notice any effects soon, but the weight will put too much stress on your hinge (this is for 32" and bigger)
With a 31, you'll be fine.
FlyersFan2009 is offline
post #6 of 15 Old 03-18-2005, 09:05 AM Thread Starter
04TJFan
Thanx for the advice. I love this forum
Scott
04TJFan is offline
post #7 of 15 Old 03-18-2005, 11:23 AM
BluesMan
BluesMan's Avatar
The only issue I had with my 31's was the new BS of my wheel was 3.75
If you do not use some kind of spacer that will allow the rubber tire stops to make contact with the tire, you may (very probable) have damage to the tailgate system.
I used Rubber mallet heads cut in half and longer bolts myself.
...Don't follow Chili Palmer into the trees...
BluesMan is offline
post #8 of 15 Old 03-18-2005, 11:30 AM
bandit5150
Try the stock mount for a while. You will be able to see the tire bouncing around if it's going to be too heavy. I ran around for a month or so with a 33x12.5 on a pro-comp alloy on the factory mount. It was quickly apparent that the tire was too heavy. The worst was the rythmic bouncing on the freeway - from the expansion joints in the pavement. The tire bounced around like Ali. A bumper / tire carrier was in order, the tailgate wouldn't have lasted long.
bandit5150 is offline
post #9 of 15 Old 03-18-2005, 02:15 PM
Oman Jeep
Oman Jeep's Avatar
Most important thing is to make sure the tire contacts all the little rubber bumpers on the tailgate area to stop it shaking.
Oman Jeep is offline
post #10 of 15 Old 03-18-2005, 05:03 PM
2to1 Jeep wins
2011 MK Compass
Hi,
Another new guy here, with a question very similar to this post.
I got a spare tire mounted rack (Thule 987xt with 943) for my 05 Rubi and was wondering how much weight the tire carrier can handle in addition to the spare. I am looking at this rack plus a pair of skis and 2 snowboards. Does anybody else use this setup?
I was going to go with the Mopar unit, but it could only carry skis.
My friends are wimpy snowboard riders , so I needed to carry both.
Thanks!
Sean
2to1 Jeep wins is offline
post #11 of 15 Old 03-18-2005, 09:16 PM
Eggs4Lunch
Tire carrier weight
04TJFan:
You should be fine. The stock Rubi 245/75 R 16 is a very heavy tire. It weighs 76 pounds mounted on the Moab rims. I would be a little cautious about adding anything else because the owner’s manual for 2004 says maximum weight for the tire carrier INCLUDING the tire and rim is 50 pounds. If you have a problem, DC will undoubtedly pull the manual out and try to rub your nose in the 50 pound comment.
Eggs
Eggs4Lunch is offline
post #12 of 15 Old 03-18-2005, 09:26 PM
Jim Shanks
Jim Shanks's Avatar
My tailgate hinges started failing even with the stock 30" gsa on it. I wouldn't trust even a 31 on the factory mount. Granted mine is a '98 and they have done something with the hinges since then, hopefully made them stronger.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
post #13 of 15 Old 03-18-2005, 10:03 PM
maxedout
I run a 33" tire on the stalk carrier without a problem, on the other hand I am waiting for my custom bumper and tire carrier to be completed.
maxedout is offline
post #14 of 15 Old 03-18-2005, 11:20 PM
Sammy Jenkins
Sammy Jenkins's Avatar
warn swing away tire carrier was the solution to my problem. <------------- in case if u ever have one.
Sammy Jenkins is offline
post #15 of 15 Old 03-18-2005, 11:28 PM
Flyingbrass
33"
And I'm right in the middle of my Jeeperman tire carrier/rear bumper install as we speak. I had to take a break.
2004 Flame Red Unlimited, 4"Superlift suspension lift, 33" BFG MT's, Pro Comp Extreme Alloys 1079's, 4.56 gears, Eaton Electric Locker, Superlift rock rings, Superlift steering stabalizer, hardtop, full set of Husky Liners, matching spare, Jeeperman rear bumper/tire carrier, Jeeperman front bumper 54" with light bar, and Warn 6" flares,
Flyingbrass is offline
31" BFG A/T Tire pressure and Spare tire carrier Questions.. jeep2029 TJ Wrangler Technical Forum 14 08-20-2009 07:31 PM
tire carrier or no tire carrier? that is the question bfaas Wrangler General Discussion 6 05-11-2009 09:27 PM
Bestop Tire Carrier or Bumper/Tire Carrier Combo dallasjetfan TJ Wrangler Technical Forum 6 12-22-2008 09:46 AM
31x10.5x15 wheel tire combo on stock tire carrier? ADIDAS TJ Wrangler Technical Forum 13 06-24-2005 11:20 AM
Rear Bumper Tire Carrier Bike Carrier Solution Cidk TJ Wrangler Technical Forum 1 05-07-2003 09:39 PM
