Quantcast which tire for the 2.5L? 32x10.5 or 31x11.5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > which tire for the 2.5L? 32x10.5 or 31x11.5
Old 04-28-2009, 04:49 PM   #1
MC_NickP
i am thinking about my next tire upgrade. which tire would be the better choice to lose as little power as possible? 32x10.5 or 31x11.5
Black 98 TJ
Low Output 4 Cylinder Jeep Club #178
build thread:
http://www.jeepforum.com/forum/f22/mc_nickps-black-tj-build-1036334/#post9499802
MC_NickP is offline   Reply With Quote
Old 04-28-2009, 05:07 PM   #2
lil-jmart13
lil-jmart13's Avatar
i have 31x10.50.15 and i couldnt notice any power loss or less gas mileage. i had 29's on before.
THE RUBBER DUCK!
2000 JEEP TJ - mostly stock - daily driver
MEAN GREEN
1997 JEEP TJ SAHARA - project mean green!
WTB: TJ HALF DOORS OR TUBE DOORS!!! PM ME!!
NIGHTCREW
-#35-
lil-jmart13 is offline   Reply With Quote
Old 04-28-2009, 05:24 PM   #3
BaystateTJ97
Did you mear 31X10.50 and 32X11.50's? Just curious..
'97 TJ Sport SOLD!
'90 YJ Laredo
Western Mass 4X4
Vote for your freedom back on November 6, 2012.
BaystateTJ97 is offline   Reply With Quote
Old 04-28-2009, 05:29 PM   #4
Imped
TITS
Imped's Avatar
I believe he did. Never seen 31x11.5 and 32.10.5.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 04-28-2009, 05:43 PM   #5
Rubicon_Rob04
With the stock suspension I think 32's would be too much. I had 31's with my stock springs and it was less than ideal over all, driving on road was no problem though.
You could "fit" the 32, just depends on what you plan to do with your jeep.
Rubicon_Rob04 is offline   Reply With Quote
Old 04-28-2009, 05:45 PM   #6
sailsurf7713
Torque is a function of radius so the larger diameter tire will result in a greater loss of torque. Also the greater width of the 32" will result in increased static and kinetic friction causing a greater "loss in power" and less gas mileage.
'99 SE: The "It could be worse..." jeep
sailsurf7713 is offline   Reply With Quote
Old 04-28-2009, 05:52 PM   #7
Yesfan70
Sailsurf's posts makes the most sense since the 32" tire you mentioned is going to be taller and wider.
Even though mine is a I-6, I did not notice any power loss when I upgraded my stock 30x9.5 tires to my 31x10.5 MT/Rs.
I would also think whatever running gears you have will make a difference. A friend of mine has 4:56 gears in his and seemed to not have any problems running 33x12.50s with his 2.5L for the longest, before doing an engine swap.
Blue Jeep Club Member #193
My Jeep Pics
I live. I wheel. I am. Jeep
Yesfan70 is offline   Reply With Quote
Old 04-28-2009, 08:17 PM   #8
mitchf350
I would just stick to the 31's i put a 2.5 rc lift and 31 km2's and a can only run 60mph in 5th gear. 5th gear is almost pointless.
97 tj. RC. 2.5" 2.2 Shocks and steering stab. 31"x10.50x15 KM2's Safari straps full cage nets.
06 Commander 4.7l
mitchf350 is offline   Reply With Quote
Old 04-28-2009, 08:22 PM   #9
RogueSpear2023
JF is my second home.
31s with that 4cyl
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
TJ Tech Boot Camp
TJ Specs
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline   Reply With Quote
Old 04-28-2009, 08:25 PM   #10
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
I have 32's on my 4 cyl., you won't like it. I am currently working on regearing to 4:88's and putting the 33's back on. Right now I can use 5th gear on a very flat road, or downhill, but uphill takes 4th gear.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 04-28-2009, 10:16 PM   #11
emev0l
With stock suspension stick with 31x10.5
If you have a 4 banger with 4.11's your not going to be happy with anything taller than a 31.
You will also want aftermarket wheels with better back spacing to run wider tires or you will rub.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline   Reply With Quote
Old 05-17-2010, 12:30 AM   #12
madflyer72
madflyer72's Avatar
I agree. I am running 31x10.5x15's on mine without any upgrade to suspension. It runs smooth but it is a ***** to go up hills lol
madflyer72 is offline   Reply With Quote
Glock Forum
