Timing Chain replacement question? What do i need. - JeepForum.com
post #1 of 5 Old 07-10-2010, 10:26 AM Thread Starter
punkmode
Im going to replace the timing chain on my girlfriends 01 TJ 4.0l. Other than the timing chain set, what else am i gonna need. I know i need a new timing chain cover seal, are there any other seals im gonna need? any special tools? and any helpful hints? Thanks.
punkmode is offline
post #2 of 5 Old 07-10-2010, 12:34 PM
wushaw
Rockin jeep
wushaw's Avatar
If you have ever done one on like a v8 then it's no different.
wushaw is offline
post #3 of 5 Old 07-10-2010, 12:39 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Timing cover gasket and crankshaft seal.
GOLENJEEPTJ is offline
post #4 of 5 Old 07-10-2010, 12:52 PM
GOLENJEEPTJ
Timing case cover alignment tool would be a + to have!You want to be able to get that pulley on over keyway without a problem.
post #5 of 5 Old 07-10-2010, 08:16 PM Thread Starter
punkmode
thank ya!
punkmode is offline
timing chain , tools , equipment , parts , replace , replacement
Timing chain replacement and TDC bstiger TJ Wrangler Technical Forum 2 08-22-2009 11:35 PM
Timing chain replacement? krash TJ Wrangler Technical Forum 5 06-06-2008 10:02 PM
'90 4.2 Timing Chain Replacement Melvin Davis YJ Wrangler Technical Forum 4 11-15-2006 04:13 PM
timing chain replacement bluegrass YJ Wrangler Technical Forum 0 06-15-2005 09:26 AM
timing chain replacement '94 4 cyl bryanjeep YJ Wrangler Technical Forum 3 08-01-2003 09:14 PM
