Timing Chain or Belt Wrangler 4 cyl.? - JeepForum.com
post #1 of 15 Old 12-19-2006, 06:39 PM Thread Starter
blazer8
I have a 97 Wrangler with a four cylinder. Does anyone know if it has a timing chain or a belt? I believe it is a 2.5L. Is that right? This is my first Jeep and I am clueless.
blazer8 is offline
post #2 of 15 Old 12-19-2006, 06:47 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It uses a steel timing chain so no worries about needing to change it on a regular basis like if it had a rubber timing belt.
Jerry Bransford is online now
post #3 of 15 Old 12-19-2006, 07:02 PM Thread Starter
blazer8
That is great news! One less thing I have to worry about right now. Thanks Jerry.
blazer8 is offline
post #4 of 15 Old 12-20-2006, 06:18 AM
Combatsylvania
Looks easy as pie to change, whats the maintenence schedule say? like 100km's or something?
Looks like you just gotta pop off that open idler pully and remove the cap and your there. One thing I like about the 4cyl is the amount of room under the under the hood.. Im thinking of putting a 5th seat in there, lol
Combatsylvania is offline
post #5 of 15 Old 12-20-2006, 09:24 AM
Jerry Bransford
Administrator
You're confusing the serpentine belt which does nothing but drive the waterpump, fan, alternator, and a/c compressor. He was asking about the timing chain whose job is to turn the camshaft. You can't see the timing chain, it's under a cover.
post #6 of 15 Old 12-20-2006, 09:56 AM
Combatsylvania
No im not, I said to get at the timing chain you pull that idler pulley (for the serpentine) and remove the cap (or cover) and your at the timing chain.. The cover is held on with 3 screws.. really easy to access..
im not completely inept,
post #7 of 15 Old 12-20-2006, 10:10 AM
jeeptj19992001
03 rubi....growing bigger and better every day...
jeeptj19992001 is offline
post #8 of 15 Old 12-20-2006, 05:21 PM
James04TJ
James04TJ's Avatar
For the search value of this thread. The 2003+ 2.4L uses a timing belt not chain as with other TJ motors.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
James04TJ is offline
post #9 of 15 Old 12-21-2006, 05:50 AM
Combatsylvania
Are you sure? I dont have a FSM for the 06, but I do have one for the 2003 and I was almost positive I read that it was a chain. It even showed a picutre with a marked link.
Ive been wrong before tho (many times). So if it is indeed a belt, how often is it supposed to be changed?
post #10 of 15 Old 12-21-2006, 06:18 AM
SpitNine
2015 JK Wrangler
2.4l Timing Belt
The 2003 thru 2006 2.4L motor has a rubber timing belt.
I'm not exactly sure of the replacement schedule but it's around 100,000 miles.
Judging from how accessable the front of the 2.4L motor is, changing the timing belt should be pretty simple.
Thanks.
2015 Sport
Six Speed
Hardtop
Fire Cracker Red
SpitNine is offline
post #11 of 15 Old 12-21-2006, 07:53 AM
Combatsylvania
Thanks.
He speaks the truth, just looked it up with the AC Delco parts search. Sais its a belt. (AC Delco part# TB265)
post #12 of 15 Old 03-14-2007, 10:35 AM
spiicytuna
So to be 100% clear.....and I am only asking because I am about to inherit a 1995 2.4L Wrangler with 114 on the OD.... pre-2003 the 2.4L had timing chains? How long are timing chains good for?
spiicytuna is offline
post #13 of 15 Old 03-14-2007, 10:40 AM
bobbert350
bobbert350's Avatar
wow thats pretty sweet if its that setup...i have the 4.2 it was a pita since i had to remove my rad and all that stuff....and it was held in by like 15 bolts and 4 that were on the oil pan
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
Why only go anywere fast when you can go anywhere
bobbert350 is offline
post #14 of 15 Old 03-14-2007, 10:50 AM
Jerry Bransford
Administrator
Let's not get confused here, the 2.4L engine currently shipping in new TJs is nothing like the 2.5L engine in that 1995 Wrangler. Make sure you realize what you have is a 2.5L engine which does use a timing chain.
post #15 of 15 Old 03-14-2007, 11:20 AM
spiicytuna
Sorry for the confusion (ignorance) on my part. Got it. 2.5L . . . . how long are timing chains normally good for? It had a "major tune-up" about 5k miles ago where the serpentine belt among other things was changed.
Timing help! Replaced timing chain now I can't get the timing right. yjcrawlr YJ Wrangler Technical Forum 29 04-09-2010 08:36 AM
Timing Belt or Chain on 97 TJ? jisigler TJ Wrangler Technical Forum 5 02-09-2007 10:56 AM
Timing chain in YJ 94 jeep_indika YJ Wrangler Technical Forum 2 01-05-2007 11:23 AM
Timing Chain! Josephrk24 YJ Wrangler Technical Forum 3 12-23-2006 07:26 AM
timing chain bobbert350 YJ Wrangler Technical Forum 2 08-30-2006 12:33 PM
