Timing belt replacement on 2.4L going bad... - JeepForum.com
post #1 of 20 Old 08-04-2013, 07:56 PM Thread Starter
Smelt_one
I borrowed a pulley puller (3 arm) from Autozone, and ended up breaking off a piece of my damper(on crankshaft) pulley flange. The pulley tool must have slipped and was biased to one side and broke off a piece of the casting (pulley is castt iron.) So now I'm in a bigger pile of dooo!
Which option to proceed on. As you may know, the pulley has 3 spoke and youtr typical puller will not work because it's designed for 4 sploke and has 2 working arms.
I don't know if there is another 3 arm puller that would do the trick. And I've seen somewhere where someone used a bearing splitter and put it behind the pulley and got it off that way. But I don't know how they pulled on the bearing splitter because of the 3 spoke pulley.
Use a sawsall and cut off the three spokes, then easy acces to pull the rest of the pulley?
Use a dremel to cut the hub and then use a chisel hammer to split the hub?
Get some dynamite and blow the thing to holy heaven?
Gey some beer and forgetaboutit?
Smelt_one is offline
post #2 of 20 Old 08-05-2013, 06:34 AM
wwch99tj
I think you should be using this type of puller...
http://www.harborfreight.com/46-piec...set-69889.html
At least that's what I used on my 99, 2.5 4 cylinder
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #3 of 20 Old 08-05-2013, 10:54 AM
4banged
I used an autozone 3 arm puller and it worked for me...my only problem was the center of the puller messed up the thread for the bolt so I had to just use a thread tapper to clean it up. It did take two tries to get the marks on the cams to line up with the crank mark (put it all back together and had to take apart again cause it was one tooth off). I'm already not looking forward to the next belt change.
4banged is offline
post #4 of 20 Old 08-05-2013, 02:16 PM Thread Starter
Smelt_one
The puller they loaned me had 2 different length rods that go into the screw hole and pulley hole. The drive screw on the puller is hollow. The longest one was too short, so I put a smaller screw into the pulley hole and tried to crank on it with the puller screw. I think the puller was not on properly, as it's hard to hold everything in place and ratchet. The rods they supply ensure that everything stays centered, and also holds the puller in place as you engage the arms properly. If they had a longer rod, I probably would not be in this situation. Anyways hopefully somebody will read this and learn from it.
I've got a shop locally that will do the work (3 hrs labor) so I;m done for now, and hopefully no valves got smacked. If I need to pull the head I will be most dissabointed.
Got beer?
post #5 of 20 Old 08-07-2013, 12:00 AM
Sudcalifornio
can u sent pics of your work step by step? i have to do it on my tj i have all the parts but the knowledge
Sudcalifornio is offline
post #6 of 20 Old 08-07-2013, 08:03 PM
bj26pro
I second that ^^ pictures would be great
bj26pro is offline
post #7 of 20 Old 08-07-2013, 08:51 PM
chris142
I just did one of these timing belts yesterday. Theres no holes in the pulley for that puller to grab. you need a special puller that goes into the deep hole where the crank bolt goes and bottoms out about 4 inches in.
BTW this is the same engine as the PTLoser uses so asking for a puller for a PT may get you the correct puller. This is the one I used.
http://buy1.snapon.com/catalog/item....re&dir=catalog
chris142 is offline
post #8 of 20 Old 08-07-2013, 09:46 PM
tytrev
You just wrecked my day with that "same engine as" info.... How many miles is time to change the belt?
97 TJ SE: Building for medium trails
62 CJ5 Willys: Restoring to original...well close to original
Who cares about my other cars? They're not JEEPS!
tytrev is offline
post #9 of 20 Old 08-07-2013, 10:04 PM
Necko2529
Your 2.5 is a "shortened" 4.0. The OP has a 2.4 which is a different engine. You can read about both on allpar.com .
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #10 of 20 Old 08-07-2013, 10:14 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
On yours?
When it slips, makes noise or breaks...
Knuckelhead is offline
post #11 of 20 Old 08-07-2013, 11:19 PM
chris142
90k according to the pt book. Don't put it off as these are valve Benders and rarely make 100k w/o the belt stripping.
Same engine as the pt but with different external bolt on's.
chris142 is offline
post #12 of 20 Old 08-07-2013, 11:59 PM
Necko2529
I took my 04 2.4L to ~113K in 3 years and 4 days from new to totalled without a hickup. I ran M1 Clean 5000 10w30 with Mopar filter from the first oil chane to the last and never had one problem. I miss that TJ.
post #13 of 20 Old 08-09-2013, 03:26 AM
tytrev
Originally Posted by Knuckelhead View Post
On yours?
Ok...your getting strange now! Stop following me weird guy!
tytrev is offline
post #14 of 20 Old 08-09-2013, 05:20 AM
wwch99tj
He's not following you he's just an active member who actually checks the current threads and offers his thoughts...
wwch99tj is offline
post #15 of 20 Old 08-09-2013, 11:27 AM
Knuckelhead
AFSOC Retired
On yours?
You asked a technical question in a technical forum, I answered it.
How is that following you around?
Its not my fault that you don't know the difference between the 2.5L engine and the 2.4L engine in a TJ (you don't have a timing belt)...
2.4l , replacement , timing belt
