Time for a Stretch...A Buildup Thread
| Ruffstuff Axle Simple Swap Kit! | Truck-Lite's New LED Headlamp Series | Spartan Lockers FREE SHIPPING Excellent Prices |
#91 | ||
Pics... [URL="http://smg.photobucket.com/albums/v516/JeepJay/"]http://smg.photobucket.com/albums/v516/JeepJay/[/URL] TJ Stretch Thread... [URL="http://www.jeepforum.com/forum/showthread.php?t=348220&page=3"]http://www.jeepforum.com/forum/showthread.php?t=348220&page=3[/URL] |
#92 | |
#93 |
Ok Home Stretch...
Coilovers "mocked" in ![]() ![]() ![]() ![]()
#94 |
Part of cage removed to mount spare tire
#95 |
Cage re-structured and Spare Mounted
#96 | |
Lifted/Locked/Rolled/Sunk
I need a 35" tire for spare. PM me if you have something. My Hummer Hole video SIRA 4x4 club I'll be Savvy someday!
#97 |
Coilovers fully mounted and partially compressed...once the fuel cell and tool box are loaded the Jeep sits just about level. The slightly higher back will settle some in the future but it is within 1/2".
#98 | |
Look at how high the jack is mounted...when mounting coilovers on anything, you absolutly must drop the axle low enough to mount the lower tab of the fully extended shock before you compress it as you are not doing it by strength alone. The ride height is equivalent to a 5.5" coil spring which is what I had previously. See the next pictures for ride height.
#99 |
Here is a good view of the double triangulated rear
#100 |
WOW is all i can say
00 TJ with a few mods. Hopefully more someday... |
#101 |
That is definatly the most badass TJ I have ever seen! Also A sweet cherokee in the background
#102 |
Looks good but still a little to tall for my taste and I would rather have that tires lower because that is a lot weight pretty high in the air and messes up your COG even more. Just my $.02, though.
Are your triangulated arms going to have contact if you fully compress one side and let the other side droop? It seems like they might since you mounted the lowers on top of the axle. Did mounting them on top of the axle not mess up your antisquat numbers because that does not give them much seperation at the axle end and it looks like you don't have any up and down adjustment for your links at the frame end? Like I said, you are doing GREAT work
1999 Jeep TJ on 1 tons (OLDER) 2003 Jeep Rubicon (OLD) 2008 Jeep Unlimited X (NEW) |
#103 |
My one newb question- there appears to be some kind of brake mechanism on the T-case output. What's that for?
edit- another one...what kind of driveshaft is required for that setup? |
#104 |
Some Call me RockDog
that's the parking brake. A regular drive shaft can be used as long as it has the bolts to attach it. should look ssomething like this...
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#105 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
