Time for a Stretch...A Buildup Thread
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#61 | |
Also finished up making the switch panel...now time to wire it
![]() What a busy weekend...
Pics... [URL="http://smg.photobucket.com/albums/v516/JeepJay/"]http://smg.photobucket.com/albums/v516/JeepJay/[/URL] TJ Stretch Thread... [URL="http://www.jeepforum.com/forum/showthread.php?t=348220&page=3"]http://www.jeepforum.com/forum/showthread.php?t=348220&page=3[/URL] |
#62 |
Onto the Long Arms...
![]() Cutting some square stock ![]() The rear arms which still need to be cut down once I figure out the exact length ![]() The front Arms ![]() With the tabs TIG'd on for the Radius Arms ![]() ![]() All thats left on the arms is to put the JJ's in which we coulden't do since we broke the tips we needed for the lathe to machine the jam nuts :banghead:
#63 |
Some Call me RockDog
Looks good... Question...
What did your 60 come out of? Is that custom or Junk yard? Did you build your 9?
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#64 | |
My 9" is completley home built. It utilizes a regular 9" housing and then I got a HP9" third member, used the thickest wall tubes I could get, and used Scout D44 outers w/ 31 spline Cromoly axle shafts...nice and light and strong. I haven't broke anything in it over the last year and it has seen some really heavy abuse but if I ever do get on a nice axle carnage streak then I will convert it into a 609 and use the 60 outers on it.
#65 |
Wow great project, I'd love to have the talent (and money) that a build like this would require. Looks great and I can't wait to see more.
1999 Jeep TJ .....pretty far gone from stock |
#66 |
what's the total stretch amount again? I'm thinking if I did one, I would keep it at around 6-7 inches to allow me to keep the tank under the jeep using the genright tank. That and I would probably just cut the rear clayton brackets off and move them back a little bit
#67 | |
1999 Jeep TJ on 1 tons (OLDER) 2003 Jeep Rubicon (OLD) 2008 Jeep Unlimited X (NEW) |
#68 |
i decided that whenever i get out of college, i want to do whatever job you do!! nice build keep us posted
02 TJ with scratches
www.handegraphix.com |
#69 | |
Yeah I think they have enough beef to not bend but I can't wait to test them out ![]()
#70 | |
#71 |
Ok...finished up my calculations for the rear suspension
the Lower arms will be 42" long and the uppers will be 38" long. This will produce the following... Anti-Squat = 81.442% RC Slope = -0.031in / in ("-" = roll understeer; "+" = roll oversteer) RC Height = 27.212in RC Angle = -1.782degrees ("-" = roll understeer; "+" = roll oversteer) Instant Center X-Axis = 185.12in Instant Center Y-Axis = 0in Instant Center Z-Axis = 36.981in Roll Over Angles 56.3 degrees Left 57.6 degrees Right 60.5 degrees Forward 66.5 degrees Rearward So far everything looks good ![]()
#72 |
Post up the spreadsheet picture of your double triangulated setup. Are you going to have any adjustability in the uppers?
#73 | |
The uppers and lowers will have soome degree of adjustability but I am not going to put a 20" threaded rod in like Clayton does.
#74 | |
As you can see I changed the length a little (before final cut & welding the tube adapters on) once I got the correct position of the axle. Wheelbase will be 106" I've used chromoly for the calulations though the schedule 80 is a bit stronger...just didn't feel likle putting in all the additional data I would have to get from the metals guide but the Yield Strength and Modulus of Elasticity are higher. ![]() ![]() SO far so good ![]()
#75 |
Here are the LA's before the Tube adapter is welded in for the JJ.
![]() at 48" long these Bad Boys are a sight too see ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
