Time for a Stretch...A Buildup Thread
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#46 | ||
The reason I went thicker with the arms is because it is stronger, I got a great deal on the materials, and that is a standard size for schedule 80.
Pics... [URL="http://smg.photobucket.com/albums/v516/JeepJay/"]http://smg.photobucket.com/albums/v516/JeepJay/[/URL] TJ Stretch Thread... [URL="http://www.jeepforum.com/forum/showthread.php?t=348220&page=3"]http://www.jeepforum.com/forum/showthread.php?t=348220&page=3[/URL] |
#47 |
Okay...got back to working on the Jeep...removed the gas tank and stripped out everything so I could cut the frame and move the axle back.
Love the clearance without the gas tank ![]() ![]() ![]() ![]() Should have the frame cut early in the week and the crossmember for the 4-link welded in by the weekend.
#48 |
awesome thread. Keep the pics comming.
#49 |
Wow what a tiring weekend...
Here are some pics from Saturday. First up some other projects we are working on... ![]() ![]() Now back to your regularly scheduled programming... ![]() Blown Hub ![]() Shock tweeked a bit ![]() ![]() ![]()
#50 |
Today I pulled the drivetrain, cut off all the brackets from the axle and generally cleaned it up. I also finally cut the rear frame off and welded a support to keep the remaining frame from moving around at all.
Unfortunetly I forgot my camera today and hopefully I will get back to the shop by the end of the week. Originally I was planning on making the rear frame out of square stock but now I am leaning towards using one long piece of tube and just bending it. Then I will tie it into my cage and into a tire carrier. More to Come...but bed for now.
#51 |
Some Call me RockDog
Anything new? How's that willys coming. Mine is still in pieces and the clayton kit should be soon.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#52 | |
) and the body parts are all in the basement being sanded and prepped while the frame is getting ready to be Por15'd I think that one won't go back on track until later this summer/fall I am back on track with the TJ...But since I am a bit tired from being oversees for the past two weeks, I only did a little work. Pulled the Steering wheel out as well as the Steering column, shafts, box, and any remaining parts of the steering system. Now that I have all of this out of the way, I can start mocking up the steering arms to connect to the Ram to make sure they are straight at full turn. I can also start bending some tube to mount the ram off the axle. I have some pictures but I won't post them until tommorrow. I completely forgot about how many electircal connections I have to change from the steering column...starter, lights, horn, turn signals, etc. I think for the meantime I am going to get a Painless Performance Switch setup to go in the rollcage...maybe a push button Start ![]() Eventually I am going to make a Stainless Steel Dash and set it up with some AutoMeter gauges, shielded switches, etc. I'm getting ready to make the rear arms but the JJ's I got from Currie are missing some parts The rear arms will be about 41" long to stretch it anywhere from 104-106"More to come... ![]()
#53 |
Looks awesome so far, keep the pics rolling! A push button start would be different, and quite cool.
Also.. nice to see some hardcore tech stuff on here.. coilovers.. mmmm... ![]()
(O|||||||O)
l_l*-----*l_l Raskull - Metallic Silver '03 Jeep TJ Sport (pic) http://myjeeptj.com <- Write-ups on mods/maintenance/trips and a video/image gallery Custom front bumper build Custom rockers build My build thread |
#54 | |
1999 Jeep TJ on 1 tons (OLDER) 2003 Jeep Rubicon (OLD) 2008 Jeep Unlimited X (NEW) |
#55 |
Looks like a fun project. I'd say those shocks are bit more than tweeked.
2005 Rubicon Unlimited Sahara Edition 605/1000 2001 WJ Limited - Sold www.rubiconsahara.com |
#56 | |
#57 |
Here is the Frame cut away
![]() ![]() ![]() The new frame is going be sleeved into the old frame at an angle. It will then bend towards the center of the tub at a 45 degree angle approx to the bumper where it will be a straight piece for about a foot before bending to the other side.
#58 |
New Clutch Installed
![]() And Drivetrain back in... ![]() Just need to fit the shift linkages for on the T-case.
#59 |
Cut some solid stock to help with the disconectable crossmember we are building...this is going to be interesting
![]() Which will slide in the original lower link bracket here ![]() And then connect to a 1 3/4 tube that will attach to this crossmember from BTF ![]() ![]() Unfortunetly I didn't have a chance to pick up some tubing so this will have to wait.
#60 |
Some more cutting...
![]() Fuel Cell and Storage test fitted ![]() ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
