Time for a Stretch...A Buildup Thread
| Truck-Lite's New LED Headlamp Series | Ruffstuff Axle Simple Swap Kit! | Spartan Lockers FREE SHIPPING Excellent Prices |
#31 | |
I was going to do a front triangulated setup. I scraped the idea because it looked like the upper arms could hir the oil pan. Best of luck if you go this route.
"Professional Driver on a Closed Course"
http://offroadiowa.com/ http://www.4x4syndicate.com/ i has a kool buggy |
#32 | |
http://store.summitracing.com/partdetail.asp?autofilter=1&part=CRT%2DP74028&N=70 0+115&autoview=sku http://store.summitracing.com/partdetail.asp?autofilter=1&part=MRF%2DMP%2D3125&N =700+0&autoview=sku I am looking into doing this or using the stock assembly in my fuel cell but I haven't decided yet.
1999 Jeep TJ on 1 tons (OLDER) 2003 Jeep Rubicon (OLD) 2008 Jeep Unlimited X (NEW) |
#33 | |
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HLY%2D12%2D920&N= 700+4294839053+400178+4294836965+4294791574+115&au toview=sku Also with the external fuel pump, you will probably need to run a return line and swap the TJ fuel rail for one from a YJ that has a return port.
Pics... [URL="http://smg.photobucket.com/albums/v516/JeepJay/"]http://smg.photobucket.com/albums/v516/JeepJay/[/URL] TJ Stretch Thread... [URL="http://www.jeepforum.com/forum/showthread.php?t=348220&page=3"]http://www.jeepforum.com/forum/showthread.php?t=348220&page=3[/URL] |
#34 | |
#35 | |
best one I could find..kinda big but you wanna be able to see the arms so I'll just link it http://members.cox.net/geauxturbo12/trevorxj2.jpg
Louisiana 4X4 '97 TJ Sport Black, 3.5" RE, PSC Trail Cage, Ford F150/Explorer Hybrid 8.8 Aussie locked, Lockright in the XJ HP 30, 4.88 gears, Borla Headers, No Muffler, 35x12.5 R15 Baja MTZs, Currie TrackBar. Homebuilt Longarm 4 link, AA HD SYE, TW CV DS, Warn tire carrier, Jeeperman front bumper, Warn X8000i with Amsteel Blue rope with a safety thimble, CO2 GeauxLook@myJeep |
#36 |
Those comp cut rears will really fill out nicely with this stretch.
Are you moving the front up at all, or just the back farther back? |
#37 |
wait u have claytons longarms. and ur making new ones ......why the hell would u do that
#38 |
glad to see another quality build, thats one of the only reasons i watch pirate is for new builds...good luck, we'll be pulling for ya to finish this before springtime
02 TJ with scratches
www.handegraphix.com |
#39 | |
1. I am making a true 4-Link front that will be triangulated instead of the radius 5-Link that Calyton uses. 2. I am stretching and possibly double triangulating the rear 3. To Learn and because I can I can accomplish both numbers 1 and 2 for for far cheaper than Clayton's stretch kit which is only the rear arms stretched and retails around $1200.
#40 |
The 14" Fox 2.5 Coilovers came in Today
![]() As well as the Hypercoils ![]() The Spring Rate is going to be 250/350 which will give an initial spring rate of 145.83.
#41 | |
#42 |
Picked up the steel to make the arms today...
Lowers- 2" Schedule 80 Square Stock 0.32 Wall Uppers - 1.5" Schedule 80 Square Stock 0.25 Wall On Friday we will start cutting the frame in half...
#43 |
What are you going to be using for threaded adapters on your square arms?
Also, any reason why you went so thick on the square arms? Clayton only uses 2x2x.25" wall lowers and 1.5x1.5x.125" wall uppers.
#44 |
Some Call me RockDog
Why not... More strength and a lower CG
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#45 |
THats gonna be hard to bend for sure
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
