Quantcast Time to Regear need suggestions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Time to Regear need suggestions
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Old 02-19-2008, 01:52 PM   #1
eprovenzano
2005 WK
I'm starting to plan out the regearing of my son's TJ. We hope to do it during the summer months. The Jeep is a 97 SE, 2.5 4 cylinder, 5 spd with 4 inch lift with 33's. We will go with the 4.88 gears. I've started to do some research, but I'm not sure as to what is needed.
I know I need to do both the front and rear... I know we want to go with the 4.88 gears. I think I've found someone I feel competent of installing the new gears, as this project is best left to the professionals. For this project, I prefer to purchase the material, and pay someone to install it.
What I don't know is beside the obvious, (new gears) what else do I need. I've seen a master install kit, not sure what it is and why its needed. Any specific brands I should look at, stay away from, etc.
Any info that the jeep Gods would like to pass along would be greatly appreciated.
05 Grand Cherokee Limited, stock for now
Son's 96 XJ 4 1/2 inch lift on 33's
eprovenzano is offline   Reply With Quote
Old 02-19-2008, 02:02 PM   #2
justin_76
Sigma Nu-Gamma Xi 1405
justin_76's Avatar
Find a reputiable mechanic and ask him what you will need. They should be able to tell you everything they will need to do the install.
justin_76 is offline   Reply With Quote
Old 02-19-2008, 02:04 PM   #3
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Are you using someone at a shop to install the gears? If so, make sure THEY provide all the parts, not you. If they provide the parts and something goes wrong with the gears after they're installed, which does happen, then they will be responsible for everything... not just the labor. If you provided the parts, then they would blame the parts you provided and even if you could get them replaced under warranty, you'd have to pay for their labor again.
Brand-wise, Spicer, Superior Axle, and Yukon have good reputations. I personally am no fan of Genuine Gear which is a house brand for 4Wheel Parts.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Old 02-19-2008, 02:21 PM   #4
Hot Sauce
The master install kit comes with stuff like new bearings, shims, ring gear bolts, marking compound, pinion nut, crush sleeve, and seals. It's needed because of all the fine tuning that needs to be done to get the new gears aligned. But like Jerry said, if you're not doing it yourself, its best to let the installer take care of that stuff.
Hot Sauce is offline   Reply With Quote
Glock Forum
