time to REGEAR - JeepForum.com
post #1 of 25 Old 12-09-2007, 07:09 PM Thread Starter
Anti-bling
time to REGEAR
Well its that time of my build! Time to regear....i havent the slightest idea of what i have or where to go to. I have an 04 sport with a D44 rear and 33's. Can anyone point me in the right direction??
'04 Wrangler Sport: Khaki, D30/D44, 2.25" BB, JKS 1.25" BL, OME Coils, Fabtech style front bumper, Herculined tub, Hi-Lift, Jerry Can, HUNSAKER ENVY seats, Flowmaster 40, CAI, Performance TB, 33x12.5's, Defender basket with SRC soft top rack, Lite Dot, CJ Tailgate, Rear Stinger.
Anti-bling is offline
post #2 of 25 Old 12-09-2007, 07:11 PM
SecondTJ
SecondTJ's Avatar
You have stock 3.73's.
Do you ever plan on going bigger than 33's? If not, then 4.56 should be where you want to be.
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #3 of 25 Old 12-09-2007, 07:13 PM Thread Starter
Anti-bling
will my mileage improve? i might eventually go to 35's...will 4.56's work then?
do i need to change the front D30, also?!
post #4 of 25 Old 12-09-2007, 07:27 PM
Michael_K
Michael_K's Avatar
Mileage improvement will be marginal, but you will get your powerband back.
You need to change your front along with the rear.
Michael K.
DailyDrivenTJ.com
JUST For Jeep TJ Owners Around the World!
Michael_K is offline
post #5 of 25 Old 12-09-2007, 07:30 PM
BYuen
BYuen's Avatar
If you ever go 35s definitely go with the 4.88s. It's what I'll be doing with my current 33s until they wear down and I can move up to 35s.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #6 of 25 Old 12-09-2007, 07:33 PM
will228
will228's Avatar
is it an auto or a 5 speed? because correct me if im wrong. Some people say that 4.56 would be better with the auto because 4.88's are too high for the three speed and u'd be running up your RPM. But if your a Stick then 4.88 would be better if u plan on going for 35's
will228 is offline
post #7 of 25 Old 12-09-2007, 07:39 PM
SecondTJ
SecondTJ's Avatar
He has a 2004, which would be the 4-speed auto trans.
Manual or 4-spd auto, 4.56 is the recommended ratio for 33's. The 4-spd needs lower gearing than the old 3spd because of the overdrive.
SecondTJ is offline
post #8 of 25 Old 12-09-2007, 07:40 PM Thread Starter
Anti-bling
Its an auto. The only problem i have is overdrive...when it kicks in at freeway speeds, it almost feels as if the jeep is about to start going backwards. Is there any way to fix this, without a regear?
post #9 of 25 Old 12-09-2007, 07:41 PM
Wrangler11
Wrangler11's Avatar
I have 4.88s with 33's and love them though I do plan to go to 35's. I do however, have a manual.
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #10 of 25 Old 12-09-2007, 07:41 PM
will228
will228's Avatar
thank you for correcting me. haha. Go for the 4.88s
will228 is offline
post #11 of 25 Old 12-09-2007, 07:44 PM
will228
will228's Avatar
you mean it bogs?. in that case a re gear would be the best thing to do unless u want a supercharger... you could do the little power add ons like intake,spacer,chip and blah blah blah but to get more power but regearing in the long run will make u a happier camper
will228 is offline
post #12 of 25 Old 12-09-2007, 09:19 PM Thread Starter
Anti-bling
yes, it bogs. Woudl a supercharger be similar in price?
post #13 of 25 Old 12-09-2007, 09:35 PM
DBLJ
DBLJ's Avatar
A supercharger will run you 3k+ easy.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #14 of 25 Old 12-09-2007, 09:43 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Supercharger would be a lot more but you should still regear first. A supercharger is not the way to correct for an incorrect/too high of a gear ratio.
Jerry Bransford is online now
post #15 of 25 Old 12-09-2007, 09:46 PM
robncar
robncar's Avatar
Do the re-gear! For 33's and the 4-speed auto you want to go with 4.88's. The overdrive on the 4-speed auto is 0.69, so the lower (higher numerically) gear is warranted. If you ever go 35's it will still work but won't be optimal, 5.13's would be better. The D30 is the limiter here; it will only go to 4.88.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
Time to regear! Vigher TJ Wrangler Technical Forum 8 01-29-2010 09:59 AM
35's, Time to regear and lock xtreampyro TJ Wrangler Technical Forum 16 12-02-2009 09:02 PM
building first jeep, time to regear goodwin2112 TJ Wrangler Technical Forum 13 03-05-2009 01:17 AM
Time to Regear need suggestions eprovenzano TJ Wrangler Technical Forum 3 02-19-2008 01:21 PM
Time to Regear...which brands are the go cj5350 TJ Wrangler Technical Forum 4 02-19-2005 12:34 PM
