Time to lift - JeepForum.com
post #1 of 3 Old 06-19-2012, 10:47 AM Thread Starter
packersxxxi
Time to lift
ok so ive been saving up and its finally time for me to lift my jeep. Just wanted to ask some more experienced jeepers a few questions before i pull the trigger. I plan on purchasing a 3" zone suspension lift with the nitro gas shocks. The kit says that it come with a transfer case drop, but i want to get a SYE and a cv drive shaft. So my question is this... do i need to drop the t-case if i buy the SYE and cv? and where would you recommend i buy the SYE and CV from? Also the lift says that i need 3.5" backspacing and the rims i want are 3 5/8"... will that work? again im new to this so any help would be appreciated! thanks guys!
2000 Jeep Wrangler Sahara, 95,000 miles, Jensen VM9214, Sony Xplode 12", Kenwood 350w amp, KC Hilites 130w Long Range lights, Warn VR8000 Winch.. Build List: 3" BDS Suspension Lift with Fox 2.0 shocks, Pro Comp Rock Crawler 152 Rims, 33x12.5 Goodyear MT/R's, LOD Rear Bumper, Metalcloaks front and rear, tom wood's SYE and CV driveshaft
packersxxxi is offline
post #2 of 3 Old 06-19-2012, 10:54 AM
Ironhead
no need for the tc drop if you are doing a sye and cv shaft
3 5/8" bs will be fine, for 12.5" wide tires, i'm running 4" bs and just barely rubs
Ironhead is offline
post #3 of 3 Old 06-19-2012, 02:27 PM
sc00bz
Can't help you on the SYE but a lot of people swear by Tom Woods as far as the DS is concerned.
3 5/8 BS will work fine.
97 TJ with some stuff.
sc00bz is offline
backspacing measurement , lift advice , sye/cv driveshaft , zone 3" lift
time to lift my 91 yj what is a good cheap lift and what 1" body lift drenter17 YJ Wrangler Technical Forum 34 06-23-2012 02:45 PM
Time to lift ksmksm2003 TJ Wrangler Technical Forum 2 02-16-2011 07:36 PM
It's about time I lift it... crosscheck17 YJ Wrangler Technical Forum 88 04-27-2006 11:35 AM
Its Lift Time!!!!! joeygeep YJ Wrangler Technical Forum 5 05-01-2005 06:16 AM
The time has come (to get more lift!!) WranglerYJ94 YJ Wrangler Technical Forum 2 01-27-2003 12:57 AM
