Time to change out the steering stabilizer? - Page 3 - JeepForum.com
post #31 of 41 Old 08-27-2013, 11:10 AM
tyvanwie
Originally Posted by drewabril
The steering wheel is still way off center though. Hopefully I will hear from the shop by lunch time
This is what I was referring to...
tyvanwie is offline
post #32 of 41 Old 08-27-2013, 11:17 AM Thread Starter
drewabril
Originally Posted by biffgnar View Post
And how do you expect the shop to adjust rear camber if that is a problem?
They can't, but at least they (according to them) can determine what is bent or out of line.
could be one of my control arms is tweaked, but I can't tell
maybe the axle housing is bent, but I can't see it with the naked eye.
At this point I have taken lots of advice from lots of threads on here, and triple checked my work. I am running out of ideas but i want to remain methodical.
After all this frustration, I don't mind spending the $70 for some professional help/advice which may save me from replacing parts that were never broken in the first place.
drewabril is offline
post #33 of 41 Old 08-27-2013, 11:20 AM Thread Starter
drewabril
I gotcha. yes i could've centered it, but i knew i'd be taking it to another shop for a second opinion anyways so i may as well get as much as I can out of the money i am spending, right?
post #34 of 41 Old 08-27-2013, 11:47 AM
RowJ
if you want to let people waste their money, that's fine.
No point in your trying to figure out what I do or do not want!
But FYI, I'd settle for fewer redundant posts.
RJ
RowJ is offline
post #35 of 41 Old 08-27-2013, 04:43 PM Thread Starter
drewabril
Should I be worried about these lock washers hanging off the tie rod?
I tried to attach a pic from my phone lets see if it works
post #36 of 41 Old 08-27-2013, 05:01 PM
rchase559
Those are typically found on either side if that locking collar. I just cut them off and didn't look back when I aligned the stock steering.
rchase559 is offline
post #37 of 41 Old 08-27-2013, 05:28 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Those are retainers used during assembly by the OEM, IIRC. You can cut them off...
Knuckelhead is offline
post #38 of 41 Old 08-28-2013, 05:12 AM Thread Starter
drewabril
well thanks to everyone here for keeping me sane.
The back of my Jeep was just fine. The second shop mentioned they had to spend alot of time getting the drag link sleeve freed from the rust that was on it, they even replaced the hardware on the sleeve. I guess the first shop just had no idea what they were doing and threw me for a loop.
My jeep is driving much better, the shaking is almost completely gone and the steering wheel is pointing straight again. I am comfortable taking my hands off the wheel and letting it track down the road by itself. In the end i probably could have saved that $70, but live and learn I guess.
Now to cut off those tie rod retaining clips and I'll move on with my life!
Thanks again everyone.
post #39 of 41 Old 08-28-2013, 06:08 AM
eduardostewart
are you saying all the problems were from a bad drag link?
eduardostewart is offline
post #40 of 41 Old 08-28-2013, 06:49 AM Thread Starter
drewabril
No, the drag link was not bad or broken, it was simply not adjusted properly. The issue was alignment all along. Here's why:
The alignment must have been bad for a while, but the stock rubber track bar bushing was absorbing the shakes/vibrations of it so I didn't notice. Eventually that track bar bushing gave up from the abuse and gave me DW. I replaced the stock bushing with a poly one, which doesn't absorb the vibration the way the stock rubber one did.
With the firmer poly bushing in place the vibrations from misaligned tires became noticeable.
post #41 of 41 Old 08-28-2013, 07:19 AM
eduardostewart
gotcha, thanks. i try to absorb others peoples trials so i have a little intellect what to look for if/when i have troubles.
