Time to change out the steering stabilizer? - Page 2 - JeepForum.com
post #16 of 41 Old 08-23-2013, 10:16 AM
dylan
Originally Posted by drewabril View Post
Thanks for the perspective.
How long has it been since you changed your stabilizer? Was yours leaking when you changed it?
I know mine is leaking, but I'm purposely waiting to do that until after I have every thing else working properly.
Thanks for the clarification.
This phenomenon would cause the opposite of my experience. So i will rule brakes out
my next step is remove the steering stab. and test drive.
Any tips on checking the unit bearings and or the u-joints in the front axle? i dont hear any noise or feel any play when I spin the front wheels.
For my SS, i purchased the jeep (2000 TJ) with 50,000 miles on it. I drove it around for few weeks then put a 4 in lift in it. Right after putting in the lift i had prety extreme DW at 35 mph. pulled off my SS and it was completly junk so i replaced it with a stock $40 autozone special, thats the only time i have replaced it and it worked great, but thats just my experience. For the cheap money its not a bad move... i thought
dylan is offline
post #17 of 41 Old 08-23-2013, 10:17 AM
RowJ
Originally Posted by Sixbanga View Post
....... No need for a stabilizer on a tj with decent tires imo.......
I totally agree that if you have a DW, steering shocks only mask true problem.
I also agree that a Steering Stabilizer is not required....especially off road!
But.... At the risk of being flamed, I would share a thread with you that opened my eyes to why the factory installs a SS in the first place. I got involved in this discussion because I have started using my TJ as a daily driver........
If interested, please read HERE
RowJ is offline
post #18 of 41 Old 08-23-2013, 05:06 PM Thread Starter
drewabril
Got an update-
I brought it back to the alignment shop because the wheel was at 10 o'clock while going straight down the road.
I talked to the tech and he said he rechecked it and couldn't get the alignment right. He said he went over the front end thoroughly and everything is tight, but the camber on one of the rear tires is out of whack.
I left the jeep there and he is going to go through the rear end tomorrow and try to figure out what is bent or out of whack. I just find it strange that i can feel the vibes and shaking in the steering wheel, if there is a problem on one of the rear wheels..
Any thoughts or input? I dont know what to make of this now..
drewabril is offline
post #19 of 41 Old 08-23-2013, 05:38 PM
geardwrong
I had the same problem on a 97 TJ. I replaced all the stuff you did plus both wheel hubs and still had DW. Took it in for a 3rd time to be aligned and they found that my rear track bar mount was broken. The repaired mount and installed both front and rear track bars. Jeep has never handled as it does now and never had DW again.
geardwrong is offline
post #20 of 41 Old 08-23-2013, 05:50 PM
tyvanwie
You can center your steering wheel and do an alignment yourself in about 5 minutes. Alignment, adjust the tierod sleeve. Centered wheel, adjust the draglink sleeve. Simple.
tyvanwie is offline
post #21 of 41 Old 08-23-2013, 07:30 PM
ops5
ops5's Avatar
I was driving down the road yesterday and the steering wheel started shaking a bit. After looking everything over today, I see that a rear wheel shed a balancing weight.
ops5 is offline
post #22 of 41 Old 08-24-2013, 09:47 AM Thread Starter
drewabril
I'm glad to see this isn't unique to my jeep. The shop I brought it to couldn't figure it out so they gave me a refund and I will take it to Sullivan tire on Monday. They deal with more trucks, so hopefully they are better able to diagnose my problem.
Based on posts here I looked at my rear sway bar, track bar and control arms, nothing looks warped or broken to me.
post #23 of 41 Old 08-27-2013, 06:36 AM Thread Starter
drewabril
Drove the Jeep to the 2nd alignment shop today, I didn't even feel the vibration on the way over. I hit 40mph several times the ride was smooth. What gives!?
The steering wheel is still way off center though. Hopefully I will hear from the shop by lunch time
post #24 of 41 Old 08-27-2013, 06:55 AM
Sixbanga
Got an update-
If the caster or camber is off in the rear you have a bent wheel or axle. Put a floor jack under the rear axle and have some one let the clutch out in first gear to spin the tires slowly. Look for a wobble. If you have a open carrier you may need to lift one side at a time so that tire will spin. Dont shift through the gears or spin the tires fast because you can damage the clutch or auto trans when the drivetrain is unloaded.
Sixbanga is offline
post #25 of 41 Old 08-27-2013, 09:02 AM
tyvanwie
I told you before that you can do it yourself it 2 minutes. It's stupid simple.
tyvanwie is offline
post #26 of 41 Old 08-27-2013, 09:27 AM Thread Starter
drewabril
If the shop cant find the root cause today, i will try that when i get the jeep back. Thanks
Thanks for pointing that out. I know that I can toe in the front on my own, but my concern is this rear camber issue.
I've inspected the rear suspension and nothing is loose or worn out or bent enough to be seen with the (admittedly inexperienced) naked eye, but something on the alignment rig is getting thrown off.
If I do have an issue in the back, the alignment shop with their experience and super accurate tools will have a better shot at determining what is throwing me off.
post #27 of 41 Old 08-27-2013, 10:44 AM
RowJ
You told him once..... so let it rest!
Some can't or don't want to DIY!
His money....his choice!!
RJ
RowJ is offline
post #28 of 41 Old 08-27-2013, 10:51 AM
tyvanwie
RJ
if you want to let people waste their money, that's fine. But I like to try and save people money.
tyvanwie is offline
post #29 of 41 Old 08-27-2013, 11:07 AM Thread Starter
drewabril
RJ
Did you see my reply above? This is not a simple toe-in toe-out issue, which I agree I could do in my driveway.
Do you have a DIY write up to adjust the camber for a rear wheel?? I do things myself whenever I can, but I know enough to figure out when i'm in over my head..
post #30 of 41 Old 08-27-2013, 11:10 AM
biffgnar
biffgnar's Avatar
And how do you expect the shop to adjust rear camber if that is a problem?
Romney in 2020!
biffgnar is offline
