Quantcast Time for another Super 35 thread - some questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Time for another Super 35 thread - some questions
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full
Old 03-10-2006, 10:28 AM   #1
JPWheeler
After reading through dozens of threads on the subject, I still have some questions. I have the stock D35 and for a while I was thinking of swapping in a D44, but I have since learned that a Super 35 kit would be sufficient (not to mention a lot easier on the wallet). Having said that, here are my questions:
- I'm thinking of going with this kit from redrock4x4 with the ARB for the carrier: http://www.redrock4x4.com/shop/products/786.html Does anyone here have this particular kit and want to comment on it?
- Is the Super 35 something I can install myself, or is it best left up to the professionals? I'm by no means an expert mechanic, but I try to do all the work on my TJ when possible. I have never touched anything in the drivetrain however. If possible, I'd like to do it myself to save on labor costs, but if I'm just asking for trouble then I'll definately have a shop do it.
- Same question as above for the ARB. Seems like some lockers are easier to install than others, but I don't hear much about how easy or hard the ARB's are to install.
Thanks
-Jon
2000 TJ Sport - Forest Green - 4.0L I6 5-Speed, Soft top, Stock D30/35c, 3.73's, RE 2" BB, 1"BL, MML, 32x11.5 BFG M/T's, 15x8 Unique black steelies, JKS QD's, Hanson 52" front, Jeeperman rear bumper/tire carrier, Jeeperman Trail Skidz, Warn 9.5ti w/ Viking Trail Line synthetic rope, Roundeyes H4 headlight conversion, 130w KC SlimLite Titanium Fogs, Pioneer HU w/ iPod integration, Cobra CB w/ Firestik II, Husky floor liners front & rear, Wet Okole neoprene seat covers FTL!
Green Jeep Club Member #80
Colorado Jeep Club Member #58
DD:
98 BMW M3 Coupe, Arctic Silver, 3.2L I6, 5-speed
JPWheeler is offline   Reply With Quote
Old 03-10-2006, 10:34 AM   #2
frankiefire702
If you don't know much about working on your jeep leave it to the professionals. I'm runnning the alloy usa kit with a detroit and am very happy with it.
06 tj locked on 36's.
frankiefire702 is offline   Reply With Quote
Old 03-10-2006, 10:42 AM   #3
bills79jeep
I think I have read from snooping around here that lockers and the like usually are only under warranty if a professional installs them. I could be wrong though, it has happened once before...
1979 CJ-5 304 V8, 32x11.5 Kumho Mud Terrains, Edelbrock Intake, Carb, Cam
1998 Cherokee, 3.5" Lift, RE HnT SYE, needs installed, 31x10.5 Firestone Destination MT's, Herc'ed Interior.
http://www.cardomain.com/id/bills79jeep
bills79jeep is offline   Reply With Quote
Old 03-10-2006, 10:58 AM   #4
geauxturbo
If these words make sense to you, do it yourself
Dial Indicator
Backlash
Runout
pinion depth
Micro Caliper
Depth Gauge
setup bearings
toe and heal
Honestly, You don't need to pull the pinion out, just swap out carriers so you likely will be able to get by with the same pinion shim. Check the run out (it shouldn't be a problem...probably don't need to check it) on the ARB and nail the backlash with a dial indicator then run your gear pattern. If its acceptable, rock and roll. If not, well...it can get little ugly. Plus, having the shims inside the carrier bearings sucks. It can be simple, or it can be alot of work. If you get it wrong, well, you could have thermal nuclear melt down of your gears
You can get pictures of acceptable gear patterns on the intraweb and what to do when the pattern shows up one way compared to the other. You'll need all the torque and specifications for the dana 35 before you start as well.
Louisiana 4X4
'97 TJ Sport Black, 3.5" RE, PSC Trail Cage, Ford F150/Explorer Hybrid 8.8 Aussie locked, Lockright in the XJ HP 30, 4.88 gears, Borla Headers, No Muffler, 35x12.5 R15 Baja MTZs, Currie TrackBar. Homebuilt Longarm 4 link, AA HD SYE, TW CV DS, Warn tire carrier, Jeeperman front bumper, Warn X8000i with Amsteel Blue rope with a safety thimble, CO2
GeauxLook@myJeep
geauxturbo is offline   Reply With Quote
Old 03-10-2006, 10:58 AM   #5
chewrocks
I have a Superior S35 with ARB. Just installing the parts would probably be doable but setting up the gears is not something that you will want to try. You need to know what you are doing to get them set up right.
Find a good gear guy in your area and take the whole kit to him and have him install it. He also needs to drill a hole in the housing and install the air fitting. From there you can install the pump, hose, wiring and switches.
The guy that did mine charged me 300 for install and set up.
chewrocks is offline   Reply With Quote
Old 03-10-2006, 01:42 PM   #6
redrock4x4
Jon,
You don't want to install it yourself if you've never done gears before. Also don't let just anyone install them, find a shop with a good reputation for installing ARB's and setting up gears. If you don't know of one in your area, call ARB direct and ask for a referral. Tell them you want to know who the best installer in your area is, not just a dealer referral.
I would suggest regearing at the same time too, seeing as the gears need to be re-setup anyhow when installing the locker. If you have 3.07's stock you're actually forced to regear as those won't work with the Super 35 locker.
$200-350 per axle is average for regearing and installing a locker.
redrock4x4 is offline   Reply With Quote
Old 03-10-2006, 03:46 PM   #7
acorn
Let's talk about the ECTED option.
Electric switched locker made by Auburn, 30 spline version finally available for D35, 4 Wheeler Supply is selling a buttload of them in the S35 Kits, and you can get it for less than the OX S35.
Anybody running one?
Now on to what I'm not sure how I feel about. Neat feature: unlocked it is a LSD. But it's a clutch pak, and it locks using clutch friction...
Talk amongst yourselves...
'01 TJ Sport - 5 speed 4.0 - 31X10.5 Kumho MTs and 3.07s
JKS BL & BMML - JKS Quicker Disconnects
Warn front bumper - Nth Oil Pan & Warn Steering Skids - Homebrew Hand Throttle
Coming soon: 4.11's - OME HD
Black Jeep Club #105
acorn is offline   Reply With Quote
Old 03-10-2006, 03:55 PM   #8
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Clutch packs... no thanks. Not a good design unless you like rebuilding diffs.
I like how my Eaton works. Open when off, spool when locked. No clutches, air lines, or cables to adjust. Pretty simple.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 03-10-2006, 05:19 PM   #9
acorn
I hear ya. But my problem is that Eaton doesn't make a 30 spline for the D35. %$@#&%!!!
Old 03-10-2006, 05:22 PM   #10
Greg.Volkman
If I were you, i'd hold out for the 44. I have a S35. I bought mine for $350 (whole axle) with 4.56's already in it. That's the only reason I have it. It doesn't make sense to buy the kit for $900, spend another $250-$300 on a master install kit and gears, and put it in your axle. Couple hundred more dollars and you could have a D44 or an 8.8. You will want one eventually, so do it right the first time.
[url]http://i2.tinypic.com/qxrsjs.jpg[/url]
Greg.Volkman is offline   Reply With Quote
Old 03-10-2006, 05:27 PM   #11
acorn
Unless you want to lock that D44.
Old 03-11-2006, 10:17 PM   #12
JPWheeler
Thanks for all the info guys
I should probably mention that I do plan on regearing at some point (I have 3.73's now). I guess it makes more sense to do it all at once. Once my 32's wear out (I'm figuring within a year or so), I'm going to 33's and I don't plan to go any higher than that. My understanding is 4.56's are perfect with 33's and the manual tranny, correct?
I wouldn't mind having a D44, but I won't get one if I don't really need it - that is unless I found a great deal on one somewhere. So far, the cheapest I've seen for a complete D44 ready to bolt in is almost $3000, and that doesn't include another ARB and 4.56's for the front D30. A S35 plus regearing for both axles and 2 ARB's would put me close to $3000. Also, wouldn't I need a shorter DS with a D44? I'm going to need a new one anyway when I upgrade to the RE 3.5" SF someday, so I'd like to just do it once if possible.
I wish I could do everything at once (lift, CV/SYE, D44, regear, ARB's) but my budget won't allow that right now. I'm left to either do it in stages or wait a while (probably a LONG while) until I've saved up enough to do it all at once.
Should I just hold off on the axle upgrades for a while, or is there a logical step-by-step process I could follow? I thought I had it all figured out, but now I'm not so sure. Whatever I do, I just want to make sure I do it right the first time.
-Jon
DD:
Old 03-11-2006, 11:53 PM   #13
kbtriumph
Death to c-clips and ARB
We just got home (8:30 PM local) from spending 4 hours changing axles in a TJ with a D35 and ARBs. The entire 4 hours was spent in the dirt on the trail under his Heep so that we could get his wheel back on to get back to the trailer.
I have broken more than my share of axles on the trail, and either fixed or limped them home but I have never had a swap that was as bad as this one. The c-clip was the root of the evil but the ARB made a bad situation a lot worse (have you ever worked on one in the field - PITA). If you ever plan on running larger than 33" tires or on anything harder than mild trails, do yourself a favor and upgrade.
I have had to fix more ARBs than any other locker and they are not very popular with the croud that I run. Most of us run Detroits or OX. I prefer the Detroit but run an OX in the back of my TJ.
Sorry about the rant, it was a long day.
'43 GPW Rock Crawler
'74 CJ6 Safari
'98 TJ DD
kbtriumph is offline   Reply With Quote
Glock Forum
