tilt and slide - JeepForum.com
post #1 of 8 Old 06-12-2007, 09:06 PM Thread Starter
dcfeeiv
tilt and slide
i have a 97 tj, which only has a passenger side tilt and slide seat
i was wondering if it would be possible to take a tilt and slide frame and put it on my driver seat?
dcfeeiv is offline
post #2 of 8 Old 06-12-2007, 11:01 PM
CETROV
CETROV's Avatar
i have a 97 and both the right and the left seat have that feature.
sahara - don't know if that makes a difference but it has both.
97 TJ
CETROV is offline
post #3 of 8 Old 06-12-2007, 11:04 PM
SecondTJ
SecondTJ's Avatar
The driver's seat should tilt & slide...
http://pg.photos.yahoo.com/ph/thamol...e2.jpg&.src=ph
The mechanism is probably just broken.
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #4 of 8 Old 06-12-2007, 11:14 PM
SJP
TJ Wrangler
My '97 SE had a driver seat with a fixed riser, and no loop to yank the seatback forward without trying to get at the little lever behind the seat. I replaced it with a later seat with the loop, and now the seatback tilts forward, but the whole seat does not completely move toward the steering wheel, which is a function of the riser.
I guess what I'm trying to say is that it will work, but will work best with the pull tab on the side of the backrest. Also, keep in mind that the seat risers decreased in height as the years went by, so it would be best to find an earlier one to maintain your stock seat height.
Steve
Minister of Propaganda
SJP is offline
post #5 of 8 Old 06-13-2007, 09:04 AM
dm0ney
Originally Posted by SecondTJ
The driver's seat should tilt & slide... The mechanism is probably just broken.
My '99 Sport also has a fixed driver seat. Meaning it won't swing up and forward like the passenger seat to allow someone to climb into the back, it can only be adjusted to slide back & forth on the track and the seat can be adjusted to lean forward/back. It's been like this since I drove it off the dealer's lot. Definitely a different mechanism underneath, so it's not "just broken".
dm0ney is offline
post #6 of 8 Old 06-13-2007, 09:26 AM
Deezul
Deezul's Avatar
same here 04 rubi, my 98 they both went up and forward
2004 Khaki Rubicon. Jeeperman Custom Brushguard and 54" bumper, Kilby steering skid, Skidrow radiator skid, SRC Rockcrawler rocker guards, UFW Al Engine Skid, OME Shocks, JKS Quicker Discos, AEM Dryflo intake;KC Slimlight 130W Long range lights, ORO LiteDots and LitePlate, Banks Stainless Monster cat-back, Eclipse stereo, BA Speakers, Jeeperman Handles, Cobra CB, interior leds... more to come.
**R.I.P NOW TOTALED** 98TJ Sport, 30x9.5 BFG ATKO's on AR Outlaw II's, K&N FIPK, Borla Catback,
Green jeep club member #139
Deezul is offline
post #7 of 8 Old 06-13-2007, 10:38 AM Thread Starter
dcfeeiv
i know 98 and after all have (or should have) tilt and slide functions on both the passenger and driver side
dcfeeiv is offline
post #8 of 8 Old 06-13-2007, 10:57 AM
Morgen251
2010 JK Wrangler
My 99 is the same, tilt and slide on passenger, not on driver
2010 JK Wrangler. Born to me on 12/28/09 when El Jeepo (TJ) decided 160K was enough, and threw a rod through a cylinder.
BUILD:
Rubi Rocker Guards; 32" Mastercraft MTs; Teraflex 2.5" Coil Spring Lift; JKS Quick Discos; JKS Front & Rear Adj Trackbars; JKS Ex Rear Swaybar links; Zone Nitro Shocks; 1.5" Rough Country Wheel Spacers; Poison Spyder Evap Skid; Cobra 75WXST; 3' Firestick quick disco; Rugged Ridge XHD Fr Bumper; Tuffy Underseat Drawer; 6" KC Long Range Hilites; Superchips Flashpaq, Crown Extended brake lines
WISH LIST: Front LCAs, Winch, 6" KC Driving Lights, Deep Cycle Battery
Morgen251 is offline
Tilt wheel no tilt pjs TJ Wrangler Technical Forum 3 02-08-2011 07:44 AM
Tilt/Slide Passenger Seat CapnDik JK Wrangler Technical Forum 18 08-03-2010 07:30 PM
tilt and slide seat and rear legroom rouxbicon JK Wrangler Technical Forum 5 02-11-2009 05:30 PM
Anyone ever added tilt to a Non tilt TJ?? duglas25 TJ Wrangler Technical Forum 9 09-23-2007 01:53 PM
slippt and slide whoridn TJ Wrangler Technical Forum 5 12-05-2003 03:55 AM
