Tighten Emergency Brake - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Tighten Emergency Brake
Poison Spyder JK LED Taillight & Wiring Harness KitsPoison Spyder JK Crusher CornersPANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 07-23-2014, 05:38 AM   #1
jrs948
E-Brake does not hold anymore even with the hand lever totally pulled. This is for a 98' TJ. Can someone point me to a step-by-step thread?
Thx.
-Justin
jrs948 is offline   Reply With Quote Quick reply to this message
Unread 07-23-2014, 06:51 AM   #2
angelo2975
Here you go http://www.youtube.com/watch?v=JePOTERmApw
[URL="http://docs.google.com/folder/d/0B6cgnpqD0OOOTHJNWFZ0WjhhU3M/edit"]http://docs.google.com/folder/d/0B6cgnpqD0OOOTHJNWFZ0WjhhU3M/edit[/URL]
2002 FSM PDF version
angelo2975 is offline   Reply With Quote Quick reply to this message
Unread 07-23-2014, 07:23 AM   #3
XTRyan
ExtremeTerrain.com
XTRyan's Avatar
Thx.
-Justin
Justin,
The Video Angleo posted is great for adjusting the drum brakes, however you can adjust the emergency brake with an open ended wrench with the two cables go into one. If you get under the Jeep and look at the bottom of the tub you can follow the cables from both brakes and see where they come together. The adjustment is pretty self explanatory form there. Let me know if you have questions!
-Ryan
Ryan H. | ExtremeTerrain.com Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
EARN UP TO $200 TOWARD YOUR NEXT PURCHASE!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
WIN a Supercharged 2015 Jeep Wrangler Rubicon!
XTRyan is offline   Reply With Quote Quick reply to this message
Unread 07-23-2014, 07:52 AM   #4
biffgnar
biffgnar's Avatar
Originally Posted by XTRyan View Post
Justin,
-Ryan
Per the FSM, adjustment should only be made at the cables when cables have been removed/replaced. All other adjustment should be made at the star wheel in the hubs.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 07-23-2014, 08:25 AM   #5
XTRyan
ExtremeTerrain.com
XTRyan's Avatar
Interesting. I keep my drums adjusted properly but my cable must have stretched. Even though the drums were adjusted the brake didn't hold well. After adjusting the cable, all was good.
OP: Of course go with what the FSM says first, but if your drums are adjusted properly and you're still not getting it to hold, adjusting the cable worked for me. Good Luck!
-Ryan
