Tie Rod Upgrade Deal? - JeepForum.com
post #1 of 3 Old 05-17-2013, 08:42 PM Thread Starter
2KJEEPMAN
I am interested in doing a tie rod upgrade to my 2000 TJ Sahara and I came across this. http://shop.advanceautoparts.com/web...ada_10185837-p
Would this work as an upgrade? I know I could get the parts from rock but this is free shipping and there is a $50 discount with code DOW20 if you spend over $125.
Is this a deal?
2KJEEPMAN is offline
post #2 of 3 Old 05-17-2013, 08:49 PM
BLK00TJ
If those pictures are accurate, no. That's the wrong part of a ZJ tie rod swap. If you order from AA, I used this parts list:
Part No ES3096L
Part No DS1312
Part No ES2079S
My total was $132.44 a few months ago with the discounts.
However, I will be replacing with an aluminum alloy rod with 1 ton joints next week that a friend is selling.
BLK00TJ is offline
post #3 of 3 Old 05-18-2013, 02:15 AM
MetalMountainGoat
yeah that is not the correct parts. You should be able to get all the parts needed from advance though for around the 140 dollar price range. They had them all in stock when I bought mine a couple weeks ago. Just tell them that you need the entire tie rod assembly from a 98 or old ZJ with the v8. The part numbers above are correct as well.
MetalMountainGoat is offline
