Tie Rod/Steering Replacement Options - JeepForum.com
post #1 of 16 Old 02-08-2005, 03:50 PM Thread Starter
mkuzmukerau
mkuzmukerau's Avatar
OK, I bent my stock tie rod, and it definatly needs to be replaced. And I probably should upgrade my stock Steering Stabilizer since I am running 33s. What setups are out there and what experiences has everyone had. Originally I was simply going to replace the Tie Rod with a RE one... But then I noticed that Currie has the whole system, but is quite a bit more.. Any suggestions??
mike
2005 LJ Rubicon w/Savvy 4" and 35's
2009 XK Limited
2008 JK Unlimited Rubicon - Sold
2007 XK Rocky Mtn 4x4 - Totalled
2004 TJ X - Sold
mkuzmukerau is offline
post #2 of 16 Old 02-08-2005, 04:02 PM
RUB1CON
RUB1CON's Avatar
that currie tie rod set looks really nice, big daddy also makes good looking tie rods but the only way they come is using the OE ends, but they say the tie rod is 4x stronger than stock, steering stabalizers OME or Rancho
'03 Rubicon
RUB1CON is offline
post #3 of 16 Old 02-08-2005, 04:24 PM
macb
macb's Avatar
there are several options...I know 2 people that run the alumiflex and are happy with it.
I run a custom one with heim joints and very large DOM tubing. Poison spyder has
a nice setup, and teraflex makes a High-Steer that is nice. the difference between the
currie and some others is that the currie includes the drag link...most of them use stock tie-rod ends though. I have seen 1 jeeper go through 3 currie tie rods so that is the experience
that I have seen - he is running 35s on very tough trails. Check and see what they have
at 4x4 group buy too.
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah:
Bob Supplee:
or (405) 799-8977
Stu Olson's great jeep resource site:
macb is offline
post #4 of 16 Old 02-08-2005, 04:56 PM
crypnite
I snapped my draglink a bit back and replaced it with the Currie. Their tie rods are the same size...and it's much much beefier than stock. Plus, Currie's great to work with, no problems and I've ordered three diff times with them so far.
09 2DR RUBICON
crypnite is offline
post #5 of 16 Old 02-08-2005, 05:09 PM
tx02tj
I ordered the Currie Setup for my jeep yesterday morning from 4x4groupbuy.com I bent my original on a tree stump.
From my reaserch this seems to be the easiest upgrade for the money. I guess the next step would be to go with sometype of hi steer setup.
tx02tj is offline
post #6 of 16 Old 02-08-2005, 05:20 PM
MattTheMudder
Ask Mr. Owl
MattTheMudder's Avatar
I'm gonna order the Currie system. Far as I know Old Man Emu, Doestch Tech, and Rancho make steering stabilizers.
MattTheMudder is offline
post #7 of 16 Old 02-08-2005, 05:28 PM
MR.CLIFFORD
MR.CLIFFORD's Avatar
I'm going with the DPGOFFROAD tie rod. It uses 3/4 ton Dodge TRE's and is extremely beefy.
Custom signature
MR.CLIFFORD is offline
post #8 of 16 Old 02-08-2005, 06:09 PM
biffstephens
biffstephens's Avatar
Off Road Onlys is really nice....
http://www.offroadonly.com/products/new/u-turn/
Biff
Wheel Spacers? Aluminum Fairleads? Winch Rope? LEDS? Winches? Accessories.....
Biff
biffstephens is offline
post #9 of 16 Old 02-08-2005, 06:21 PM Thread Starter
mkuzmukerau
and holy crap expensive... Man if that Currie was just a bit cheaper....
Mike
2009 XK Limited
2004 TJ X - Sold
post #10 of 16 Old 02-08-2005, 06:40 PM
wipedawg
wipedawg's Avatar
I like that...
I looked on the website and its not there.. where did you get yours?
Silver Jeep Club Member # 829.3
6 in lift, 35" Interco Trxus MT's, long armed, Bushwacker cut-out flares, Skyjacker coils(powdercoated grey), RE 4.5 extreme duty leaf packs, Tera 1.5in shackles, AJ's Superrails, AA SYE, TW DS, Blacked out all around. and a buncha RE trackbar stuff, and the infamous ZJ tierod :)
wipedawg is offline
post #11 of 16 Old 02-08-2005, 06:41 PM
MR.CLIFFORD
Originally Posted by wipedawg
I like that...
Give Dirk a call at 316.776.9900 and he can hook you up. Tell him Andy sent you.
Custom signature
post #12 of 16 Old 02-08-2005, 06:49 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
mind if I ask what their current price is? I don't see it listed under Currie on the 4x4GB site...
mkuzmukerau...might want to read this:
Alumiflex Tie Rods
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #13 of 16 Old 02-08-2005, 06:55 PM
wipedawg
wipedawg's Avatar
what'd it run ya? you can PM me if you dont wanna say out loud
wipedawg is offline
post #14 of 16 Old 02-08-2005, 08:06 PM
WVZJ
If you want a cheap alternative you could run a tie rod from a V8 ZJ. They are quite a bit beefier than the stock TJs.
98 ZJ 5.2, LA n Locked, 242 sye, 35's
87 MJ, 4.0, 8.8, 33's, oba
07 Ram 2500 5.9 ctd
WVZJ is offline
post #15 of 16 Old 02-08-2005, 08:09 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
Jason at RedRock4x4 has the Currie for $379 shipped on his site...
Greg
D30 Replacement Options? SuperWade2 TJ Wrangler Technical Forum 47 04-05-2009 05:09 PM
Steering gear box replacement options BUSAFREAK TJ Wrangler Technical Forum 2 07-25-2007 12:50 PM
top replacement- options paroxysym TJ Wrangler Technical Forum 3 03-15-2007 07:50 AM
AX5 replacement options. superjoe YJ Wrangler Technical Forum 4 06-27-2005 06:46 PM
Transmission replacement options phoen1c1an TJ Wrangler Technical Forum 2 11-24-2004 06:57 AM
