Tie rod ends total cost? - JeepForum.com
post #1 of 9 Old 08-01-2013, 12:16 PM Thread Starter
mkiv808
Shop wanted ~$800 with all parts and labor to do all tie rod ends, including alignment.
Seems like way overkill to me.
What should I expect for this service? Is it worth upgrading to beefier components if I'm not going to offroad much at all?
2001 Jeep Wrangler SE
2009 BMW M3 Coupe
mkiv808 is offline
post #2 of 9 Old 08-01-2013, 12:20 PM
Tonellin
Upgrade your tie rod and ends by doing the V8 ZJ swap yourself..the only alignment a shop can do is adjust you're toe-in. You can do that yourself in the driveway after you replace your tie rod with a tape measure. Total cost to you for the moog V8 ZJ parts should be less than $120..
http://www.stu-offroad.com/steering/zjtie/tierod-1.htm
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #3 of 9 Old 08-01-2013, 12:22 PM
biffgnar
biffgnar's Avatar
Yes, that is high. I work in Stamford every day. I could come by and help you do it yourself if you wanted. Need to know exactly what they mean by "all tie rod ends". Maybe better to step back and ask what is the problem? Depending on what the problem is and what they are replacing we could probably have it done in 1-2 hours and a couple hundred bucks in parts for you. Oh, and on the alignment all they're going to do is set the toe which is simple to do yourself also.
biffgnar is offline
post #4 of 9 Old 08-01-2013, 02:01 PM
matthew900
matthew900's Avatar
get this:
http://www.ebay.com/itm/STEERING-Jeep-Grand-Cherokee-93-95-98-5-2L-TIE-ROD-ENDS-/140499371995
Pick up the 2 adjuster sleeves at the junkyard and you can do the upgrade for under $100 with new tie rod ends. Granted they are low quality and will have to be replaced sooner but they get the job done.
Stu's website has instructions for doing the alignment yourself.
matthew900 is offline
post #5 of 9 Old 08-01-2013, 07:31 PM Thread Starter
mkiv808
Thanks for all the tips. That eBay set is lower quality? I'll definitely spend a little extra for it to last.
What's the deal with the adjuster sleeves?
2009 BMW M3 Coupe
mkiv808 is offline
post #6 of 9 Old 08-01-2013, 07:36 PM Thread Starter
mkiv808
It looks like from Napa the ZJ parts are more than $120? Each tie rod end is $50 and the tie rod itself is $100
2009 BMW M3 Coupe
mkiv808 is offline
post #7 of 9 Old 08-01-2013, 09:20 PM Thread Starter
mkiv808
So glad I stumbled upon this image:
Going to get under the car and see for myself what's worn and what isn't. The mechanic I had look at the vehicle before I bought it had stated the drag link end that connects to the pitman arm was worn. Nothing about the others.
If it's just that one drag link end, I assume that's a pretty easy part to swap out? Any watch-outs?
2009 BMW M3 Coupe
mkiv808 is offline
post #8 of 9 Old 08-01-2013, 09:37 PM
BYuen
BYuen's Avatar
It's easy to swap out. Nothing hidden will get in your way.
BYuen is offline
post #9 of 9 Old 08-01-2013, 11:01 PM
releaseme3
Just finished doing that exact job. Fairly simple. Might need a pickle fork to get the end off the pitman arm. Unscrewing the tire rod end out of the drag link was time consuming because it was kinda rusted on there. Make sure you get it on there with the same measurements of the old one or your steering wheel will be off center. Take a drive and adjust it accordingly if so. Might take a few tries. Took me three to get it centered.
releaseme3 is offline
