Quantcast "ticking" noise when engine is running - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > "ticking" noise when engine is running
Old 12-08-2008, 09:51 AM   #1
Nick12790
hey fellow jeepers. my problem is i just replaced my drive belt because it was squeaking and cracked. i inspected all the pulleys and all seemed well, and no bearings had went out. i reinstalled and tightend to less than 1/4 of an inch play between the power steering and the other pulley that isnt attached to anything, under and to the right of the a/c. that was about a month ago. since then the belt i guess has streched a little and has about a half inch play in it. whenever the car is running, there is a ticking noise that happens irregular intervals. could tightening the belt fix the problem? ive heard once you initially strech them out that much, you shouldnt strech them anymore, and my dad thinks the belt is "tight enough"
Nick12790 is offline   Reply With Quote
Old 12-08-2008, 10:21 AM   #2
Brown Dog
Vendor
Brown Dog's Avatar
Go to AutoZone and have them check the tesnion on the belt. I think they have a tension gauge
Brown Dog Offroad
http://www.browndogoffroad.com
The Jeep Forum Discount is ON!!
Join our FaceBook group
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% MADE IN AMERICA
OFFROAD-REVIEW of Browndog Superkit
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
3.5" Superlift SL
AA SYE
35" BFG Mud Terrains
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline   Reply With Quote
Old 12-08-2008, 10:21 AM   #3
medDOyj
where does the ticking seem to be coming from? front of the engine? back? top? bottom?
pictures 1989 yj Sahara 258 6cyl auto <-- updated occasionally
a build thread awaits....
medDOyj is offline   Reply With Quote
Old 12-08-2008, 10:22 AM   #4
Nick12790
i cant really tell but when i pour water on the drive belt it stops raddeling
Old 12-08-2008, 11:58 AM   #5
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Ticking is usually an exhaust leak it would have nothing to do with the belt or rattling like you spoke of?
GOLENJEEPTJ is offline   Reply With Quote
Old 12-08-2008, 12:03 PM   #6
medDOyj
so is it a ticking or a raddling?
ticking is usually a bad spark plug wire (a miss) or like it was said ^^ an exhaust leak
does the ticking change with rpms or change after the engine warms up?
Old 12-11-2008, 09:12 AM   #7
Nick12790
it changes with the RPMd. i know my rear bolt for the exhaust mani has cracked off. the sound sound like it is coming from the front of the engine. whenever i fool around with the tension of the drive belt, it seems to change the sound volume, and pitch
Old 12-11-2008, 09:37 AM   #8
coiner13
when i first got my 97 tj i noticed a tick,tick. i thought it was lifters, but it turned out to be (with the knowlege of some info on the net) coming from the purge can/purge solenoid. haynes repair manual has details about how the system works. hope this helps, robert.
coiner13 is offline   Reply With Quote
Old 12-11-2008, 10:25 AM   #9
djt283
If this started after the belt change, and messing with the belt stops it, start by re-tensioning the belt. Check a manual, but 1/2" of play seems excessive. Mine doesn't have an adjustment, so I'm not sure about tj's. I'm not sure how or where you're measuring but every belt I've ever changed has needed to be tightened again a bit after the install.
I agree that a ticking noise should have nothing to do with the belt but you also describe it as rattling and say it changes when you tough the belt.
djt283 is offline   Reply With Quote
Old 12-11-2008, 12:12 PM   #10
medDOyj
^^ x2 i'd say its got something to do with your belt tensioner
Old 12-11-2008, 04:53 PM   #11
Nick12790
ok new news. i poured water onto the belt and the sound went away temporarily. the belt is tightened to specs. when the belt was off, i checked the pulleys i could spin with me hand, and no problems. what would you recommend doing? the sound is driving me insane
Old 12-11-2008, 05:06 PM   #12
GOLENJEEPTJ
Start it up for a short amount of time without the belt on,then listen! You also stated you have a broken off exhaust bolt on rear?
Old 12-11-2008, 05:12 PM   #13
bradbodigon
my jeep ticks, but i'm pretty sure that it is coming from the exhaust manifold. the reason i say this is because once my jeep gets fully warmed up, the ticking goes away. i think that once it is warmed up, them manifold seals better because metal expands when it is heated up, therefore creating a better seal. hope this helps.
'99 Jeep Wangler. Red. D30 Front/D35 Rear. Low Output 4 Cly. 4.10 Gears. 4 Inch Lift w/ 33 Inch BFG All-Terrains. Diamond Plate Rocker Guards. Cobra CB. Pioneer Head Unit/Speakers. Smittybilt Front/Rear Bumpers. 100w Procomp Lights. And Other Mods. And More to Come. Hoagland Fire Department. Fire Fighter #1348. Love Every Minute Of It.
bradbodigon is offline   Reply With Quote
Glock Forum
