Ticking 4.0, Adjust Valves??? - JeepForum.com
post #1 of 23 Old 11-29-2005, 10:08 AM Thread Starter
snowflakega11
Ok this is my first post here it goes. My 2000 wrangler w/ 4.0, and 105k miles is kinda running rough well ticking to be exact, and i was thinking about adjusting the valves. I have put all types of cleaners( expect the lucas which i wanna do soon) in the gas tank, and have tryed different types of oil additives but still kinda ticks if you know what I mean. Well i have been around a few of the 4.0s and some 4.2's and they usally seem to kinda tick around 100k miles. So i was wondering if there are anyway of getting rid of that sound. Also has anyone ever adjusted the valves and if so what height should i adjust them to. Does anyone else have this same problem and know a solution to it. I don't think it's a big deal because my Dad's cherrokee did the same thing around 100K and we sold it at around 200k and still kinda ticked and ran very well. I just wanna try to get that ticking to go away. And is jeep coming out with a diesil wrangler or what!
snowflakega11 is offline
post #2 of 23 Old 11-29-2005, 10:27 AM
igofshn
Locked @ both ends
igofshn's Avatar
I have 110k on mine and it purrs like a kitten. Your lifters are hydraulic and never need adjusting. Are you sure the ticking isn't coming from yur exhaust manifold which is known for cracking?
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #3 of 23 Old 11-29-2005, 10:34 AM Thread Starter
snowflakega11
I will check but i don't think so, i'm willing to try anything.
post #4 of 23 Old 11-29-2005, 10:43 AM
RockRunner85
Maybe you have carbon buildup on the heads and thus the ticking. You try decarbonizing the engine? You can use Seafoam or slowly drip water down the intake.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #5 of 23 Old 11-29-2005, 10:47 AM
newcaddy4j
newcaddy4j's Avatar
I probably don't count, but my lifters on my 4 cyl make noise for a little, then shut up. Very annoying. I'm thinking about doing an adjustment, but I wouldn't know where to begin. So for now I'll sit back and watch this forum...
Jeepless....
Keep it Real Ol' XJ and TJ
"Many men go fishing all of their lives without knowing that it is not fish they are after."
newcaddy4j is offline
post #6 of 23 Old 11-29-2005, 10:47 AM Thread Starter
snowflakega11
That sounds like a great idea. So i should go and get some sea foam from like an auto parts store, and are the diretions on the container or is there a certain way to do it.
post #7 of 23 Old 11-29-2005, 10:52 AM
Jim Shanks
Jim Shanks's Avatar
FWIW, my injectors make quite a bit of noise, kinda sounds like lifters. With a mechanics stethascope (sp?) I can tell it's definately the injectors though.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
post #8 of 23 Old 11-29-2005, 02:02 PM
wrangler2002
i'm not sure if hydraulic lifters need adjusting (they might): http://www.centuryperformance.com/valveadjustment.asp
but make sure the ticking are not your injectors. use a stethoscope to narrow down the sound. my injectors tick like crazy...so i have just learned to ignore them (they have been doing it since new)
wrangler2002 is offline
post #9 of 23 Old 11-29-2005, 02:09 PM
o2tj
o2tj's Avatar
4.0's are not adjustable. 28 ft pounds w/ a tq wrench is it.
o2tj is offline
post #10 of 23 Old 11-29-2005, 02:39 PM
Achped
How can you differenciate the ticking of valves and injectors without a stethascope?
Achped is offline
post #11 of 23 Old 11-29-2005, 02:44 PM
o2tj
o2tj's Avatar
A long extention such as 3/8 about 12" long out of you tool box
o2tj is offline
post #12 of 23 Old 11-29-2005, 03:25 PM
Jim Shanks
Jim Shanks's Avatar
A wooden dowel also works very well. Just hold one end up to your ear with the other against what you're listening to. Plugging your other ear amplifies it even more.
Jim
post #13 of 23 Old 11-29-2005, 06:16 PM Thread Starter
snowflakega11
Awesome i'm gonna try to go and get me a stethascope. Then listen in to the injectors and see if that is the problem. I also put some lucas injector cleaner in there today and it really help quiet my engine a good bit.
Thanks for the help everyone!
post #14 of 23 Old 11-29-2005, 06:21 PM
coorsmgood
coorsmgood's Avatar
2010 JK Wrangler
just use the hose from your vacume or shop vac!!!
2010 4 door wrangler stock for now in burnt orange longhorns style!!
coorsmgood is offline
post #15 of 23 Old 11-29-2005, 06:24 PM
Awshux
Cynical Bastard
Awshux's Avatar
I'm going to second the manifold question. Mine had a tiny hole and it sounded exactly like a ticking noise. Don't overlook the obvious.
You live and learn. At any rate, you live.
-Douglas Adams
Awshux is offline
Engine Ticking sound, Valves or Tapits? GreyfoxVt YJ Wrangler Technical Forum 8 09-22-2009 08:35 PM
How do you adjust valves? robertb6963 TJ Wrangler Technical Forum 15 10-27-2008 07:41 PM
Ticking sound from valves Jonman03 TJ Wrangler Technical Forum 23 05-29-2008 09:59 AM
do you need 2 pcv valves? whyjay YJ Wrangler Technical Forum 2 01-05-2006 03:36 PM
4.0 valves ryanxj YJ Wrangler Technical Forum 10 08-05-2003 11:29 AM
