Thrust Angle & Alignment Question
| Truck-Lite's New LED Headlamp Series | GR8TOPS Introduces the Exogate HD Tire Carrier | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Hey guys. Got my lift and tires on and I went to get the toe and caster corrected on the TJ today. I noticed that my thrust angle is out by about 2*. My alignment tech suggested correcting it if I wanted optimal tire wear and optimal drivability. I don't really have an extra $350 to spend on upper and lower CA's at this point, so my question is...
Will being out by 2* really chew on my new BFG's? Of course, I'd rather it be "on", but I understand it is a Jeep. What is the least expensive correction?Opinions?
Got ignorance? Please see below. [QUOTE=kd4yor;4763909]Chris, I just think your having buyers remorse for all the work in your 8.8 for no added gain (over the Dana 35).[/QUOTE] Last edited by Chris @ GATR; 03-14-2007 at 11:28 PM.. |
#2 |
All you need to adjust on a solid axle jeep with a 2" lift is toe-in. You can easily do it yourself for free.
#3 |
Did you notice that I said the toe and caster are already done? Thanks.
Anyone like to chime in on the original question?
Got ignorance? Please see below. [QUOTE=kd4yor;4763909]Chris, I just think your having buyers remorse for all the work in your 8.8 for no added gain (over the Dana 35).[/QUOTE] |
#4 |
Wouldn't the thrust be adjusted by trackbars?
#5 |
Ah, I see where LCAs would come in to play.
#6 |
Trackbar centers the axle left and right, but doesn't change the angle to the frame.
#7 |
I have the cam bolts on mine. With that said my cam angle is 5.5. About .5* out. I belive 6 - 8 is the range, 7 being optimal. My cam bolts are adjusted as far as possible. Cam angle will not affect tire wear. It will make the stearing feel light, since the cam angle is low. Higher cam angles will make the steering feel heavy.
#8 | |
Master of Reality
Chuck
Chuck Grissom Black Jeep Society Member My Jeep Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas A. Edison |
#9 | |
Do it right or not at all
![]() Join Date: Jan 2003
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#11 | |
#12 |
pirate squirrel
Hey Chris . . . tell us about your lift . . . also - has your jeep ever been wrecked ?
- Chuck - Nth Degree 4.5" short arm the "Dude" abides |
#13 |
2" BB.....1" PA BL.....Stock Shocks. As far as I can tell, the Jeep has never been wrecked. It has no signs at the core support, bumper mounts or on the frame. Unless someone did a really good cover up job, then I would say it is immune to any accidents so far. Also to Jerry, 5.5* is where I was before cam bolts. I guess I was ok?
#14 |
all you need is a adj trackbar not LCA's. the axel is not center it is to the left. i do alignment on jeeps alot(work for a jeep STEALership) teraflex has a good trackbar. that is what i have.
#15 |
Ahh, so an axle can get out of "square" with the frame because of my type of lift and cause ultimately cause the axle angle/alignment to be out? I thought a trackbar corrected the axle "centering". (left and right), not diagonal/square adjustment.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
