throwout bearing? - Page 2 - JeepForum.com
post #16 of 19 Old 07-21-2010, 09:27 PM
TJnIT
Yes the shift fork in the picture is correct. I would suspect the trowout bearing is getting seized to the quil. Sounds like its time to drop the trans again. I work at a transmission shop and luckily removing an ax15 out of a wrangler is a day at the beach compared to most other vehicles. Nebraska
Also when you fist installed it, did you put grease in the pilot bushing? If so . Oil lite bushings do not like grease. It makes them guald up and seize to the input shaft causing similar symptoms.
TJnIT is offline
post #17 of 19 Old 07-21-2010, 09:44 PM Thread Starter
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
where in NE are you?
seized to the quil? what does that mean?
everything was new a month ago.
i was reading this article: 1997 Jeep TJ Clutch Replacement
and i didnt lube the ball and socket or the sleeve of the input shaft like it says. would that be THAT big of a deal that would make my TO bearing toast in a month? i assumed that the TO bearing was prelubed to begin with.
Mail crawling.
MisfitSeven is offline
post #18 of 19 Old 07-21-2010, 09:54 PM
TJnIT
Im in Norfolk. The quil is what the TO bearing slides on, it also serves as the bearing retainer. You are correct, the TO bearing should come prelubed. And no not lubing the ball and sockets shouldn't cause that problem. In my opinion the "sleeve" (quill) that the TO bearing slides on should be VERY LIGHTLY lubed. Did you lube the pilot bushing that is in the crank on the engine?
TJnIT is offline
post #19 of 19 Old 07-22-2010, 05:51 AM Thread Starter
MisfitSeven
MAiL Crawler.
yes. that i did lube. plus that was new too.
Mail crawling.
throwout bearing , clutch , ax15 , tranny , transmission , issue , TJ
Possible Throwout Bearing? Libtekguy TJ Wrangler Technical Forum 4 02-06-2010 01:05 PM
Pilot bearing/Throwout bearing? TJ4JT TJ Wrangler Technical Forum 9 11-03-2009 02:07 PM
spun bearing or throwout bearing bad gearhead1985 YJ Wrangler Technical Forum 5 05-31-2009 12:42 AM
ax-5 throwout bearing? sasquachYJ YJ Wrangler Technical Forum 2 01-23-2009 10:49 PM
How can I tell if my throwout bearing is going bad? pushead YJ Wrangler Technical Forum 4 07-11-2006 10:20 AM
