Throttle Valve Cable Adjustment - JeepForum.com
post #1 of 9 Old 05-19-2010, 02:24 PM Thread Starter
johny84
Hello,
Can anyone help me with The Throttle Valve Cable Adjustment ?
Thank You
johny84 is offline
post #2 of 9 Old 05-19-2010, 02:37 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Do you have a FSM?...
Knuckelhead is offline
post #3 of 9 Old 05-19-2010, 02:50 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The FSM is a little helpful for this.
From the FSM:
TRANSMISSION THROTTLE VALVE CABLE ADJUSTMENT
The transmission throttle valve is operated by a
cam on the throttle lever. The throttle lever is operated
by an adjustable cable (Fig. 177). The cable is
attached to an arm mounted on the throttle lever
shaft. A retaining clip at the engine-end of the cable
is removed to provide for cable adjustment. The
retaining clip is then installed back onto the throttle
valve cable to lock in the adjustment.
A correctly adjusted throttle valve cable will cause
the throttle lever on the transmission to move simultaneously
with the throttle body lever from the idle
position. Proper adjustment will allow simultaneous
movement without causing the transmission throttle
lever to either move ahead of, or lag behind the lever
on the throttle body.
Checking Throttle Valve Cable Adjustment
(1) Turn ignition key to OFF position.
(2) Remove air cleaner.
(3) Verify that lever on throttle body is at curb idle
position. Then verify that transmission throttle lever
(Fig. 178) is also at idle (fully forward) position.
(4) Slide cable off attachment stud on throttle body
lever.
(5) Compare position of cable end to attachment
stud on throttle body lever:
Cable end and attachment stud should be
aligned (or centered on one another) to within 1 mm
(0.039 in.) in either direction.
If cable end and attachment stud are misaligned
(off center), cable will have to be adjusted as
described in Throttle Valve Cable Adjustment procedure.
(6) Reconnect cable end to attachment stud. Then
with aid of a helper, observe movement of transmission
throttle lever and lever on throttle body.
If both levers move simultaneously from idle to
half-throttle and back to idle position, adjustment is
correct.
If transmission throttle lever moves ahead of, or
lags behind throttle body lever, cable adjustment will
be necessary. Or, if throttle body lever prevents
transmission lever from returning to closed position,
cable adjustment will be necessary.
Throttle Valve Cable Adjustment Procedure
(1) Turn ignition switch to OFF position.
(2) Remove air cleaner if necessary.
(3) Disconnect cable end from attachment stud.
Carefully slide cable off stud. Do not pry or pull
cable off.
(4) Verify that transmission throttle lever is in
fully closed position. Then be sure lever on throttle
body is at curb idle position.
(5) Insert a small screwdriver under edge of
retaining clip and remove retaining clip.
(6) Center cable end on attachment stud to within
1 mm (0.039 in.).
(7) Install retaining clip onto cable housing.
(8) Check cable adjustment. Verify transmission
throttle lever and lever on throttle body move simultaneously.
Wheelin98TJ is offline
post #4 of 9 Old 05-19-2010, 05:00 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The JB translation: Take out the slack and no more, that's it.
Jerry Bransford is online now
post #5 of 9 Old 05-19-2010, 05:56 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Why do you think you need to adjust?
GOLENJEEPTJ is offline
post #6 of 9 Old 05-19-2010, 07:16 PM
stuff2c
Mine shifted terrible into 3rd (held 2nd way to long then hard into 3rd) SO i adjusted it one notch at a time... went the wrong way the first time 2 notches the other way and it shifts LOTS! better. my .02
Thanks to the interstate highway system... most people don't see nut'n in the USA.
stuff2c is offline
post #7 of 9 Old 05-20-2010, 03:38 AM Thread Starter
johny84
First, Thank you all..
Ok, I started adjusting but I seem to need some clarification:
It says "Compare position of cable end to attachment stud on throttle body lever", But if I do that , the pedal ends up being too hard to press. Maybe im getting this wrong..
I removed the white clip and tried to align the end of the plastic which connects the cable to the lever, to the stud on the throttle lever. Then I put the clip back on. Am I doing this right ?
Thank You!!
johny84 is offline
post #8 of 9 Old 05-20-2010, 01:53 PM
stuff2c
maybe this will help
stuff2c is offline
post #9 of 9 Old 05-20-2010, 05:41 PM
Jerry Bransford
Administrator
The proper adjustment for the TC cable inside that red circle is precisely when there is no slack or tension on the short length of bare unsheathed TC cable where it connects to the throttle lever.
When the throttle lever is at rest, there should be no tension (pull) on the TC cable from the throttle lever, and there should be no slop either. Tighten the TC cable just enough until the slack is out and then lock it into place.
Adjusting Throttle Valve Cable? Divinitous TJ Wrangler Technical Forum 2 08-05-2009 06:46 AM
4.0 Throttle cable/spring adjustment? mudjive YJ Wrangler Technical Forum 0 07-06-2009 10:33 AM
Throttle cable adjustment? Rubikahn TJ Wrangler Technical Forum 3 11-15-2008 09:36 AM
Throttle Valve Linkage adjustment? TEXASRAM YJ Wrangler Technical Forum 0 08-08-2005 01:44 PM
throttle cable adjustment? Muddeprived TJ Wrangler Technical Forum 7 12-28-2004 02:54 PM
