Throttle Position Sensor replaced, but code keeps popping up - Page 4 - JeepForum.com
post #46 of 47 Old 01-18-2011, 12:09 PM
Judd_S
Originally Posted by cj777 View Post
Is your horn and cruise control (if equipped) working? Airbag light on? The feed for TPS goes through the clockspring, so it can cause that error code too. May not be your issue but worth a check
I had a complete Clockspring failure (the entire ribbon inside the clockspring had sheered off) and it did not generate a check engine light. 1999 TJ 4.0 )
Judd_S is offline
post #47 of 47 Old 07-16-2011, 10:50 AM
PurpleTJ
So my jeep got wet and now i am having the same problems. Just replaced the TPS but the problem persists. Horn works, havent checked if CC works but im pretty sure im in the same boat here. I thought i heard a slight whistle that wasnt normally there while driving home from work yesterday, so i will check that and hope its a vac line, but im really hoping its not the clockspring
Purple Jeep Club member #8
PurpleTJ is offline
p0123 , position , sensor , throttle
P0123 Code - Throttle Position Sensor/Switch A Circuit High Input troutfishermen TJ Wrangler Technical Forum 6 11-20-2010 03:02 PM
Throttle Position Sensor Code jmreagan TJ Wrangler Technical Forum 8 05-10-2010 02:58 PM
Throttle Position Sensor (TPS) replaced... FKemp3 TJ Wrangler Technical Forum 10 03-15-2010 09:25 PM
P0122 CODE Throttle Position Sensor Voltage Low JeepDoo TJ Wrangler Technical Forum 2 09-27-2009 08:20 PM
Trouble Code - 122 Throttle position sensor voltage low cajunjeep TJ Wrangler Technical Forum 2 01-09-2007 07:29 AM
