Throttle Position Sensor replaced, but code keeps popping up - Page 3 - JeepForum.com
post #31 of 47 Old 07-13-2010, 08:11 PM
adudenamedsean
Originally Posted by zachbh View Post
The thing is, I did. I replaced it, followed all the instructions the FSM gave me, and was careful to make sure the shaft was correctly positioned. And somehow it still got srcewed up . Frustration ensued afterwards...
I learned my lesson. I'm embarrassed, but I learned my lesson.
Two years ago my TPS started throwing a code and acting up also. I installed a new one and it didn't fix it. Thinking I bought a bad one, I went back to the parts store and got a new one. Didn't fix it either. During all of this, I was installing it exactly how I had read too. I even reset the computer by disconnecting the battery. I eventually spoke with a family friend who worked at the Jeep dealership and he said it had to be calibrated. So he took the Jeep to work with him one day and it came home running beautifully. I have no clue what he did, but it fixed it. So, maybe we have special Jeeps?
adudenamedsean is offline
post #32 of 47 Old 07-13-2010, 08:37 PM Thread Starter
gatesjeff33
What year was your jeep?
gatesjeff33 is offline
post #33 of 47 Old 07-13-2010, 08:39 PM
adudenamedsean
It's a 98
post #34 of 47 Old 07-13-2010, 08:46 PM
MikalCarbine
These TPS's shouldn't require any calibration, unless perhaps it's on the PCM side? While dealing with certain problems from my new TPS's (weird idle to WOT range from scanner, 10-69% and voltages from TPS don't match FSM specs) I spoke to a service tech at a dealership. He was puzzled by what I told him but suggested I come in and they use a DRB Scanner to reset my ECU. I asked him if this was similar to a battery pull and he said that they actually go in and delete information. For $94 I was not about to find out if this was actually true or not. Could this be the calibration everyone is speaking of? The FSM states that the PCM learns a voltage for the minimum TPS value and that the actions for several calculations (fuel management, WOT threshold, some fuel cuttoff values, etc) are based off of this learned idle voltage. If the PCM does need to be calibrated to relearn this idle TPS value then this is something we cannot do ourselves or without a DRB scanner which costs $8k. To the OP, did you try resetting your PCM like suggested? Did you try a 8-10 hour (overnight) clearing?
MikalCarbine is offline
post #35 of 47 Old 07-13-2010, 10:02 PM
zachbh
This makes me feel great I still have no clue what I did wrong, or what the mechanic did to fix the problem. Glad I'm not alone!!! haha
zachbh is offline
post #36 of 47 Old 07-14-2010, 04:55 PM Thread Starter
gatesjeff33
what year was your jeep?
post #37 of 47 Old 07-14-2010, 04:59 PM
zachbh
2003
zachbh is offline
post #38 of 47 Old 07-15-2010, 07:48 PM Thread Starter
gatesjeff33
So I disconnected the battery for over 10 hours last night and it ran much better in the morning, but I still have a hiccup in the acceleration and the TPS high voltage code is still there. My cruise control still does not work either.
post #39 of 47 Old 07-15-2010, 07:50 PM
adudenamedsean
I would say its definitely the clockspring then. Disconnect it from behind the steering wheel and see how it runs. the clockspring and the TPS share a common ground.
post #40 of 47 Old 07-26-2010, 06:45 AM
zupatun
If you've been having hiccups and your cruise does not work the "hiccup" may have dislodged one of your vaccum lines. My TPS needs replacement (scanner) and in the last couple months I've had to go and push one of the vaccum lines back on after a "hiccup".
Open the lid and listen inside for a whistle that sounds like a vaccum leak on the right side of the engine compartment, there are at least a couple places where a vaccum line might get dislodged...worked for me.
Matt
zupatun is offline
post #41 of 47 Old 07-26-2010, 06:14 PM Thread Starter
gatesjeff33
My clockspring was bad and everything is working perfectly now that it is replaced. It cost me $214 plus tax. I would highly recommend finding one at a junk yard... there is a lot of money to be saved on this part.
post #42 of 47 Old 07-26-2010, 06:24 PM
Vandano
Originally Posted by robncar View Post
Just curious, why do you recommend the positive cable first?
Ive always done that cause being an electrician you disconnect the hot first because if there is a load on the circuit the neutral will be hot if you remove it from ground.
Originally Posted by never monday View Post
when life gives you lemons.....make a trail rig out of it.
Vandano is offline
post #43 of 47 Old 09-22-2010, 10:20 PM
natetgreat
having excact same problems no cruise control code 24 already replaced tps also digital overead dir. and temp disply comes and gos wipers work even when igntion is turned off but i dont have air bags and drivers window was out while parked for months so it rained thru hole a few times but no clock spring no air bag HELP 1992 cherokee larado 4.0 auto run fin shifts wrong tep gauge bounces all over the place
natetgreat is offline
post #44 of 47 Old 09-22-2010, 10:21 PM
natetgreat
post #45 of 47 Old 09-23-2010, 06:55 PM
tjdriver
for the cruise issue, try the brake light switch. mine wouldn't work at speed and that was all it was. the cruise light would come on and everything but wouldn't hold speed.
i fd up my clockspring when i changed my steering box a few years ago. my horn and cruise didn't work.
i picked up a used one on egay for like 75 i think. it was way cheaper than a new one.
i did have a tps problem bout 6 mths ago. i picked up a new one from advance auto and it lasted about half a day. i had to exchange it for another one and it worked fine after that. i used the flashpaq to clear the code.
i did not do the reflash of my comp.
every couple of days or so my jeep will just shut off while idling. dunno what the heck it is. no codes or check engine light. i replaced the cps and cps around the same time as the tps. i was getting a camshaft sensor/bank 1 circuit 1 when it would die out. i changed the upstream o2 sensor and the camshaft sensor and the cps and it still does it, but with no codes. dang heep
hope this helps
tjdriver is offline
p0123 , position , sensor , throttle
P0123 Code - Throttle Position Sensor/Switch A Circuit High Input troutfishermen TJ Wrangler Technical Forum 6 11-20-2010 02:02 PM
Throttle Position Sensor Code jmreagan TJ Wrangler Technical Forum 8 05-10-2010 01:58 PM
Throttle Position Sensor (TPS) replaced... FKemp3 TJ Wrangler Technical Forum 10 03-15-2010 08:25 PM
P0122 CODE Throttle Position Sensor Voltage Low JeepDoo TJ Wrangler Technical Forum 2 09-27-2009 07:20 PM
Trouble Code - 122 Throttle position sensor voltage low cajunjeep TJ Wrangler Technical Forum 2 01-09-2007 06:29 AM
