throttle body conversion nightmare - JeepForum.com
post #1 of 2 Old 11-17-2006, 05:27 PM Thread Starter
garym31
So i converted my throttlebody to a 4.0. I found one of a 98 xj for 40 bucks at a u-pull it. I get it home and put it together and its idling at about 2500 even after switching out the sensors and i look and its all cracked....!!!!!! Do they crack easy because I swear it wasnt cracked when I put it on.....is there anyway that i did it???
garym31 is offline
post #2 of 2 Old 11-17-2006, 06:49 PM
SteveS
If you overtighten the bolts yes it will crack.
SteveS is offline
throttle body and throttle body spacer laxin15 TJ Wrangler Technical Forum 11 08-24-2009 03:47 PM
Throttle Body conversion cmb516 TJ Wrangler Technical Forum 2 07-24-2008 12:30 PM
4.0 Throttle Body Conversion JeepDrivr93 YJ Wrangler Technical Forum 2 10-12-2004 02:41 PM
Throttle Body Conversion important Q CanukYJ YJ Wrangler Technical Forum 22 09-22-2003 10:34 PM
Nightmare with Poly Body Mounts 87yjNY YJ Wrangler Technical Forum 2 08-21-2003 01:42 PM
