Thoughts about this lift?? Skyjacker 4" Economy Lift Kit with Hydro Shocks - JeepForum.com
post #1 of 32 Old 02-29-2012, 09:07 AM Thread Starter
Enimo
I have a 97 tj with 2" BL. Would like to add 33's. I want the best look and ride possible without spending $1000's. Should I remove BL and add SL or keep BL and add smaller SL? Also, thoughts on the 4" Skyjacker Economy Lift with Hydro from Quadratec??
Enimo is offline
post #2 of 32 Old 02-29-2012, 09:47 AM
TJamie
I wouldn't buy it - that kit doesn't come with nearly enough parts for a 4" lift kit. You'll definitely need adjustable track bars, and you'll need adjustable control arms if you ever decide to get rid of the t-case drop. The Hydros are cheap shocks and won't be a very smooth ride either. Ultimately you won't save any money by going this route.
If you're just looking to fit 33's on a budget and look okay, do a 2" BB in addition to your BL. You'll keep your stock coils, get upgraded shocks (maybe) and won't have to deal with a t-case drop. And you'll only spend $300 and have it installed in a day.
TJamie is offline
post #3 of 32 Old 02-29-2012, 09:57 AM
rda616
Remove the 2" body lift and replace it with a 1.25" then add a 2-2.5" spring lift. Check out the dpg deluxe kit. 2" of bl is just to much for a number of reasons.
rda616 is offline
post #4 of 32 Old 02-29-2012, 10:27 AM
drewtj05
There are really too many things wrong with the parts that come with this lift kit. First off you don't need the DPA, doesn't come with an adjustable trackbar. For the money I wouldn't waste my time. The shocks are decent for the price they are nice riding hydros if you are looking for a soft ride. If budget is the issue I would go with the Zone offroad 3" lift kit . This lift kit you could always add an adj. trackbar or just redrill the axle side mounting hole. And if you want gas charged shocks they are upgradable for only $21.
drewtj05 is offline
post #5 of 32 Old 02-29-2012, 11:26 AM
STIFLER
DOODOO /thread
0311/2531 USMC YUT
STIFLER is offline
post #6 of 32 Old 02-29-2012, 02:57 PM Thread Starter
Enimo
thanks STIFLER for your fine comments. I ASSume you never had questions and was a professional from day one. Congrats!!
Enimo is offline
post #7 of 32 Old 02-29-2012, 03:14 PM
STIFLER
oh sorry.. let me try again! That kit is great you should buy 2 of them! and it was day 2 that I turn pro
0311/2531 USMC YUT
STIFLER is offline
post #8 of 32 Old 02-29-2012, 03:30 PM Thread Starter
Enimo
Oh, sorry Mr Marine, I just now saw the UMC in your title....semper fi bro...
Enimo is offline
post #9 of 32 Old 02-29-2012, 03:31 PM
wolfcreek
FWIW I think that "doodoo" was his opinion on the lift, not your post.
I had this lift and wasn't happy at all... the PO installed it and I replaced it.
wolfcreek is offline
post #10 of 32 Old 03-05-2012, 06:29 AM
STIFLER
DING DING DING
and it is USMC for the record
and Semper Fi
0311/2531 USMC YUT
STIFLER is offline
post #11 of 32 Old 03-05-2012, 06:55 AM
Sundowner
As said above: ditch the tall body lift and get a 1" or 1.25" kit from a decent/reputable manufacturer. I would do a motor mount lift at the same time, to prevent drilling your fan shroud. You can get a 2" budget boost/coil spacer, but that doesn't address your shocks at all. For the price of the BB, you could get decent shocks, and the springs aren't that much more.
Check DPG...they have good stuff from OME. JKS makes MML blocks, or you can spend $100 on the Brown Dog versions. Savvy, Daystar, etc. make good BL kits. Or, if you want to do it all at once:
http://dpgoffroad.com/products/old-m...-wrangler-kit/
That gets you in at $1000, and you have quality components. If you can't swing $1000 now, then do it next month if at all possible. There's nothing more expensive than doing something the cheap way.
Sundowner is offline
post #12 of 32 Old 03-05-2012, 07:07 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Why is 2" too much?
Wheelin98TJ is offline
post #13 of 32 Old 03-05-2012, 07:14 AM
aparke4
I agree with the above posts - the skjacker economy rides like crap - my friends GF's TJ had one when she bought it and within the week we replaced the entire kit even though it was like new! The poly arms and t case drop just did not cut it... I would actually prefer my RC 2.5 with a 1.75 spacer over the SJ 4 inch coils and the RC coils are notorious for being stiff... I think the rock ready coils have a softer rate but do not quote me on that.
aparke4 is offline
post #14 of 32 Old 03-05-2012, 07:21 AM
aparke4
Originally Posted by Wheelin98TJ View Post
Why is 2" too much?
the gaps are ugly and even though it is safe, 2 inches of body lift will give you issues with t case shifting, slight alteration of steering shaft between wheel and box and fan shroud problems.
1.25 is not noticeable at all and paired with MML gives you vibe free performance. On my 01 I did not have to modify anything - just installed MML's same day and rolled.
aparke4 is offline
post #15 of 32 Old 03-05-2012, 07:29 AM
Sundowner
Why is 2" too much?
Same as mentioned above. It was my understanding that the shifters/linkages and steering column could start to pose issues at anything over 1" or 1.25"...I hate the way it looks, too, but my commentary was based on physical issues.
If I'm wrong on that, PLEASE correct me.
Edit: also, the fan shroud and motor mounts...although I think I've seen 2" raised motor mounts at Brown Dog...but that's a lot of drivline angle change.
Skyjacker 4" Economy Lift Kit with Hydro Shocks for 97-02 Jeep® Wrangler TJ as00519 Wrangler General Discussion 2 05-21-2011 08:46 AM
Skyjacker 2" Spacer Lift with Hydro Shocks wshockley TJ Wrangler Technical Forum 7 03-31-2011 04:18 PM
Skyjacker 2" lift with hydro shocks bozhoz TJ Wrangler Technical Forum 4 02-16-2011 04:50 PM
Skyjacker 4" Value Flex Sport Lift Kit with Hydro Shocks JeepJeep04 TJ Wrangler Technical Forum 11 07-23-2010 09:43 AM
Skyjacker 2" Lift with Hydro Shocks PSYCH0 TJ Wrangler Technical Forum 58 12-28-2008 02:28 PM
