For those of you with LED tails... - Page 2 - JeepForum.com
post #16 of 37 Old 01-22-2013, 01:29 PM
wazilian
Originally Posted by socaldaveh View Post
That's my back up light!
Oh I know, I was just messing with ya. Those things are bright as heck though.
Black '97 TJ Sport 4.0L Auto 112,000 miles
BFG AT 30's, Skyjacker Hydros, JKS Quick Disco's
Dynomax Super Turbo CatBack
Black Hard Top...when its on
Garfield Air Freshener
And there's a frame under there too...I've seen it
wazilian is offline
post #17 of 37 Old 01-28-2013, 05:21 PM
Backcountry
Originally Posted by giles45shop View Post
I bought a pair of these 2" LED's for $24.95
http://www.ebay.com/itm/2-White-2-Ro...item20cbfa1efd
and installed them in my tire carrier. I used a hole saw to cut the holes in the tire carrier and ran the wires inside the carrier tubing and then out the backside near the hinge point on the passenger side.
Biggest problem was that I ran into the reinforced section of the C-channel from the hinge that was welded inside the tube on the passenger side when I was cutting that hole. I had to use my plasma cutter to finish making a hole for it.
You can also see the license plate light (normal incandescent bulb ~ $8 from auto parts store) and my LED side marker lights ($7 from Tractor Supply) in the second picture.
Tail lights are Grote 53312 Super Nova's (24 LED's Hermetically sealed, $35 each) from here:
http://www.ryderfleetproducts.com/gr...ed-p-w38-53312
Do those small led backups put out a decent amount of light?? Enough to see behind you while wheelin??
Backcountry is offline
post #18 of 37 Old 01-28-2013, 06:38 PM
rob78
My wife bought me the ORO LEDs last Valentines day.
rob78 is offline
post #19 of 37 Old 05-26-2013, 05:14 PM
aparke4
Just added angled 6 inch ovals with 3/4 side markers and soon 3/4 back ups:
aparke4 is offline
post #20 of 37 Old 05-26-2013, 05:15 PM
aparke4
Side:
aparke4 is offline
post #21 of 37 Old 05-26-2013, 05:16 PM
aparke4
Rear:
aparke4 is offline
post #22 of 37 Old 05-26-2013, 05:18 PM
Icarus
Looks good!
What did you use for the tiny ones by the rear flares? Those are 3/4"?
Ϣr
Icarus is offline
post #23 of 37 Old 05-26-2013, 05:41 PM
aparke4
Used 3/4 amber for front tube fenders:
aparke4 is offline
post #24 of 37 Old 05-26-2013, 05:49 PM
aparke4
Originally Posted by Icarus View Post
Looks good!
3/4 reds- still need to add the inline rectifier and resistor so it runs at half intensity... plus i am adding 3/4 white back ups- once they come in ill wrap it all up... the fronts are amber and are wired like stock... i used the psc ep-26 5 pin flasher and the 2 wire led write up.
aparke4 is offline
post #25 of 37 Old 05-26-2013, 05:59 PM
sjones26573
You build those front tube fenders yourself? Or are early 'Cloaks different from the main line?
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #26 of 37 Old 05-26-2013, 06:10 PM
aparke4
yeah- hybrid metal cloak 4 inch flares with cut stock inners... bolted, welded/ tied into sliders and the front end is welded with 1 inch tube and some 1/8 sheet metal to fill gaps. came out pretty nice...
aparke4 is offline
post #27 of 37 Old 05-26-2013, 06:12 PM
sjones26573
It does look nice. It took me a sec to realize they weren't stright 'Cloaks.
Jeep-Owner.com
post #28 of 37 Old 05-26-2013, 06:13 PM
aparke4
Pics:
image-1033573550.jpg   image-1807592328.jpg   image-1256985726.jpg   image-3477385201.jpg
aparke4 is offline
post #29 of 37 Old 05-26-2013, 06:17 PM
aparke4
the gap has since been filled: i ordered the mc ball weld on washers that fit the fender to help get them lined up- then bolted the flares on and welded the flares on... they are never coming off! also had a friend tig the inside against the psc defender armor.
aparke4 is offline
post #30 of 37 Old 05-26-2013, 06:23 PM
peicherokee
I did 1 inch white led's they are awesome plenty bright for my needs
THE MORE MUD THE BETTER
PEI JEEPERS MEMBER
peicherokee is offline
LED lights
