those with auto-dimming compass temp. mirror - JeepForum.com
post #1 of 15 Old 04-17-2007, 09:44 PM Thread Starter
JeepMKcomin
Does anyone know where the outside temperature sensor is located?
If possible could someone trace the sensor wire to it?
06TJ Silver Ruby - REBB w/DT3000s, Quick Discos, Superwinch EPi9.0, Warn engine skid, PS Box Skid, Diff Guards, IPF Lenses, x51s soon
92YJ White - Slight Shackle Lift w/30x9.5 BFG ATs, Custom Beefy Bumpers
06TJ Khaki Sport - Traded in
JeepMKcomin is offline
post #2 of 15 Old 04-17-2007, 09:52 PM
PackMan
PackMan's Avatar
Location: Home of the Super Bowl XLI Champion Indianapolis Colts
I think it's up in front of the radiator. A brilliant DCX move that always makes the mirror report a higher than actual temp.
OTH, just having an LED display in my mirror makes me feel better about parking my modest Jeep next a built TJ with 1-ton axles and 37" tires.
PackMan is offline
post #3 of 15 Old 04-17-2007, 09:55 PM Thread Starter
JeepMKcomin
haha
Thanks for the response PackMan
Can anyone else confirm this?
post #4 of 15 Old 04-18-2007, 06:46 AM
jeeparoo
the temp sensor if standing in front of the jeep is down low on the passenger side tucked into the grille, and yes it seems to always read a degree or two high... esp since the sensor is BLACK it will also pick up radiant heat from anything warm....
-Christopher
Ordered 2008 4dr 11/24/07 got it 12/28/07 - mall crawler - goin for gadgets on this one. COMFORT
Jeep Memories:
76 Cherokee Chief - got rusty (sold)
97 TJ Sahara 5sp soft top - mudded,sanded,rocked,sunk(sold)
00 TJ Sport 5 sp soft top - mudded, rolled in a blizzard{no damage except top} (sold)
02 TJ Sport auto soft top - roadtripped,mudded (sold)
06 TJ gold eagle 6 sp soft top- not enough room (sold)
Number 10 million of the 'I Love my JeeP' Club
jeeparoo is offline
post #5 of 15 Old 04-18-2007, 06:52 AM
el guapo
I'm interested in this, too - I've thought about picking up a mirror that has HomeLink for my garage door operner. How is power supplied up to the mirror?
el guapo is offline
post #6 of 15 Old 04-18-2007, 06:56 AM
TJromes
I have the electrical end on the driver side, low, just behind the grill. You should be able to see it looking through the grill next to the headlight. I assume that's where the sensor would be.
romes
03X
TJromes is offline
post #7 of 15 Old 04-18-2007, 08:43 AM
Mick VT
Mick VT's Avatar
If you dont have the sensor fitted the connector is attached just inside on the bottom of the grill.
If you mount the sensor using the DCX bracket it will sit in front of the rad and read high (especially when the vehicle is standing).
You can however mount it below the grill / rubber seal and save the cost of the bracket - I just used one of the "christmas tree" fasteners for the rubber seal to attach mine.
Here is a good write up if you are thinking of adding the mirror: http://www.wanderingtrail.com/Rubi_2...lec_Mirror.htm
Of course this is only this easy if you are trying to fit the mirror to an 03 or later.
Mick VT is offline
post #8 of 15 Old 04-18-2007, 08:49 AM
sparkeep
It is also a handy way to keep tabs on the temperature of your winch when in use
2005 Impact Orange Rubicon
6 speed standard 4.0L I6 engine
Mechanical Engineer behind the wheel
Toronto, ON, Canada
sparkeep is offline
post #9 of 15 Old 04-18-2007, 10:48 AM
Rocky529
Rocky529's Avatar
All 2003+ Wranglers are pre-wired for the mirror. The mirror plugs in under the dash cover and the sensor plugs behind the grill into an existing plug.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #10 of 15 Old 04-18-2007, 01:04 PM
highrisetj39.5
I have one in my 2000 Tj and i love it
2000 Tj 4.7L supercharged, with a nv3500 and SYE np231. Currie Hp 9"s w/ 4.56 and arbs, rubicon express 4.5" SF, 1" BL, 35" BFG M/T, warn m8000, all custom armor, cage and bumpers front and rear with tire swing away, CB, Currie HD steering, and some other things
highrisetj39.5 is offline
post #11 of 15 Old 04-18-2007, 02:55 PM
yellj
Just keep in mind it is inaccurate as hell when crawling, unless I haven't been through Death Valley, bet regularly see temps at 110-115 when its only 90 out when wheeling.
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416
yellj is offline
post #12 of 15 Old 04-18-2007, 03:05 PM
grymsr
Vintage Member
grymsr's Avatar
I like the auto dimming feature a heck of a lot more than the stupid temp readout.
How's that Hope and Change workin for ya?
Black Jeep Club v1.0 and v2.0 #1776
2004 Rubicon
2013 JKU Sport
grymsr is offline
post #13 of 15 Old 04-18-2007, 03:19 PM
Mick VT
Mick VT's Avatar
Consider relocating the sender as I described - still not 100% but much more accurate
Mick VT is offline
post #14 of 15 Old 04-18-2007, 06:18 PM Thread Starter
JeepMKcomin
My thoughts too, just wondering how the wiring goes
post #15 of 15 Old 04-19-2007, 09:27 AM
Flipside
Flipside's Avatar
Don't mean to burst your bubble, but my 06 Unlimited doesn't. Apparently, the pre-wire harness for this option went the way of cup holder inserts
Flipside is offline
Compass/Temp/Auto dim mirror swap (detailed with lots-o-pics) zachjf TJ Wrangler Technical Forum 181 04-18-2016 01:05 PM
Auto-dimming mirror wiring harness Yeoman TJ Wrangler Technical Forum 41 12-04-2010 10:40 PM
Installed Auto Dimming Rear View Mirror w/ Compass and Temperature, $70 OEM Slithering_Joe TJ Wrangler Technical Forum 2 06-07-2009 11:17 AM
Auto Dimming Mirror with Homelink Expat_J33P_Fan JK Wrangler Technical Forum 8 02-27-2009 01:28 PM
Auto-Dimming Rear View Mirror w/ Compass & Temperature sensor Oman Jeep TJ Wrangler Technical Forum 3 10-22-2004 10:30 AM
