-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   those with auto-dimming compass temp. mirror (http://www.jeepforum.com/forum/f9/those-auto-dimming-compass-temp-mirror-403565/)
JeepMKcomin 04-17-2007 09:44 PM
Does anyone know where the outside temperature sensor is located?
If possible could someone trace the sensor wire to it? :confused:
PackMan 04-17-2007 09:52 PM
I think it's up in front of the radiator. A brilliant DCX move that always makes the mirror report a higher than actual temp.
OTH, just having an LED display in my mirror makes me feel better about parking my modest Jeep next a built TJ with 1-ton axles and 37" tires. :thumbsup:
JeepMKcomin 04-17-2007 09:55 PM
:D haha
Thanks for the response PackMan
Can anyone else confirm this?
jeeparoo 04-18-2007 06:46 AM
the temp sensor if standing in front of the jeep is down low on the passenger side tucked into the grille, and yes it seems to always read a degree or two high... esp since the sensor is BLACK it will also pick up radiant heat from anything warm....
-Christopher
el guapo 04-18-2007 06:52 AM
I'm interested in this, too - I've thought about picking up a mirror that has HomeLink for my garage door operner. How is power supplied up to the mirror?
TJromes 04-18-2007 06:56 AM
I have the electrical end on the driver side, low, just behind the grill. You should be able to see it looking through the grill next to the headlight. I assume that's where the sensor would be.
romes
03X
Mick VT 04-18-2007 08:43 AM
If you dont have the sensor fitted the connector is attached just inside on the bottom of the grill.
If you mount the sensor using the DCX bracket it will sit in front of the rad and read high (especially when the vehicle is standing).
You can however mount it below the grill / rubber seal and save the cost of the bracket - I just used one of the "christmas tree" fasteners for the rubber seal to attach mine.
Here is a good write up if you are thinking of adding the mirror: http://www.wanderingtrail.com/Rubi_2...lec_Mirror.htm
Of course this is only this easy if you are trying to fit the mirror to an 03 or later.
sparkeep 04-18-2007 08:49 AM
It is also a handy way to keep tabs on the temperature of your winch when in use :laugh:
Rocky529 04-18-2007 10:48 AM
All 2003+ Wranglers are pre-wired for the mirror. The mirror plugs in under the dash cover and the sensor plugs behind the grill into an existing plug.
highrisetj39.5 04-18-2007 01:04 PM
I have one in my 2000 Tj and i love it
yellj 04-18-2007 02:55 PM
Just keep in mind it is inaccurate as hell when crawling, unless I haven't been through Death Valley, bet regularly see temps at 110-115 when its only 90 out when wheeling.
grymsr 04-18-2007 03:05 PM
I like the auto dimming feature a heck of a lot more than the stupid temp readout.
Mick VT 04-18-2007 03:19 PM
Consider relocating the sender as I described - still not 100% but much more accurate
JeepMKcomin 04-18-2007 06:18 PM
My thoughts too, just wondering how the wiring goes
Flipside 04-19-2007 09:27 AM
Don't mean to burst your bubble, but my 06 Unlimited doesn't. Apparently, the pre-wire harness for this option went the way of cup holder inserts :mad:
The time now is 05:57 PM.
