Thinking this terrible noise might be wheel bearings...what do you think about these? - JeepForum.com
post #1 of 6 Old 03-07-2009, 04:33 PM Thread Starter
A1A-LJ
Wheel bearings
I got this wierd rattle grind terrible noise from front end that i cant figure out...was going to replace u-joints and have been really leaning towards my wheel bearings being bad....
what do you think of the above items? seems cheap. although i dont know if i need the whole asymbly or not. can you direct me to more info?
the lame google search for the forum didnt tell me much...got a lot of cherokee links....
A1A-LJ is offline
post #2 of 6 Old 03-07-2009, 04:55 PM
brunosplace
Go to http://www.rockauto.com and get the Timken ones for $77.89 each, instead of the knock offs for $100.99 if you need them.
Originally Posted by Boodyrider View Post
Big tires, done right, are FREAKING EXPENSIVE. Deal with it, or don't go there.
Originally Posted by woodnjeep View Post
I live in the land where they salt cure roadkill.
97 Jeep TJ Sport, 4.0L, Auto, 3" BDS Lift (SOLD)
98 Jeep ZJ Laredo 4.0L, Auto, Stock
, parted out and scrapped
96 Jeep XJ Sport, parted out and scrapped
brunosplace is offline
post #3 of 6 Old 03-07-2009, 06:18 PM
Tom Hartz
1967 CJ5
Do Not Buy Cheap. I did it once and the new set of bearings made the same noise as the old bad ones. Then I replaced them with a good set and the problem went away. This also goes for heater cores, ask me how I know that also. Bottom line you get what you pay for.
Tom
Tom Hartz is offline
post #4 of 6 Old 03-07-2009, 06:43 PM
brunosplace
Tom
Timken is a well known and respected brand name, unlike the other one called OE Brand that is more expensive. I'll take the Timken's any day over those, even if the prices were reversed.
post #5 of 6 Old 03-08-2009, 06:45 AM
Cowboy1629
Cowboy1629's Avatar
I agree the Timken are the best. I purchased a cheep Chinese made unit that didn't even last 1 year. Replaced it with a Timken bearing unit and no problems since.
|______
|l ,[____],
l---L –OlllllllO-
()_)-()_)--o-)_)
Cowboy1629 is offline
post #6 of 6 Old 03-08-2009, 07:20 AM Thread Starter
A1A-LJ
that seems like valuable info. thanks guys. will definitely go with the good brand.
what symptoms do you experience when your wheel bearings need replacing? At slow speeds, high speeds etc.
A1A-LJ is offline
New to YJs. Temps, Trans Noise, Wheel Bearings imstillatwork YJ Wrangler Technical Forum 4 11-17-2009 09:07 PM
replaced wheel bearings same squeaking noise back??? snakester14 TJ Wrangler Technical Forum 9 04-09-2008 04:27 PM
Help me diagnose a terrible noise. jwhutch TJ Wrangler Technical Forum 6 11-27-2006 04:45 PM
Terrible grinding noise?? BigTal YJ Wrangler Technical Forum 7 03-20-2005 11:18 PM
Terrible Clunking Noise From Underneath ixl4 TJ Wrangler Technical Forum 4 11-03-2003 10:18 AM
