Quantcast Thinking of making my own steel storage trunk. How much for steel? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Thinking of making my own steel storage trunk. How much for steel?
Old 03-29-2006, 05:43 PM   #1
DINOCAVE
formerly CPT Jeep
DINOCAVE's Avatar
I want to make my own steel storage area. Just a really simple design with sides, a top and a front. No floor and I'll access it through the back door.
I can do all of the design, mounts and painting. I'll just need a metal shop to do a couple of cuts and bends.
ANYWAY, how much is unpainted 1/8" steel? Let's just say for a 4'x4' sheet and a 6'x6' sheet.
Has anyone done this?
DINOCAVE is offline   Reply With Quote
Old 03-29-2006, 05:51 PM   #2
Tri_X_Troll
1986 MJ Comanche
Steel is heavy. Use aluminum.
Ryan- "I went from one crap-tastic drive train to another. At least the engine is the weak link this time"
Tri_X_Troll is offline   Reply With Quote
Old 03-29-2006, 05:53 PM   #3
Bigbob
Bigbob's Avatar
Depends on where you live. If you have a couple steel supply houses that also do the shear and break deal then 1/8" is pretty cheap. Just measure exactly what you want and they can cut it out for you. They will give you an estimate. I'd re post this in the fab shop if I were you. Lots of good info there. Bob
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline   Reply With Quote
Old 03-29-2006, 06:58 PM   #4
Geeps
http://www.onlinemetals.com/
Not the cheapest, but it will give you an idea of the costs.
Geeps is offline   Reply With Quote
Old 03-29-2006, 09:42 PM   #5
fundabug
I made this one from a big metal ammo crate that I bought at an army surplus store. Painted it with Dupi-color spray on bed liner. I put a couple of handles on the lid for easy lifting and a key lock that bolts through the box through a metal plate on the inside. when the lock is closed the mounted screws cannot be reached. I also bolted a few hooks through the box to lock down my soft doors and whatever so that they don't wander off while I'm at work. I bolted the whole thing down through a metal plate from the inside to the hole where the rear seatbelts mount so I know the box won't be taken out. Total cost: $50 and a Saturday afternoon.
fundabug is offline   Reply With Quote
Glock Forum
