Thinking of going to 35inch tires - JeepForum.com
post #1 of 34 Old 03-17-2013, 12:40 PM Thread Starter
Elganja
I bought my 2000 Jeep Wrangler Sport (D30/D35) almost a year ago.. the previous owner lifted it 4inches + 2inch body lift (6inch total) and put 33's on it, but did nothing else ... since then I have added a Smittybilt XRC front and rear bumper w/ tire carrier and their XRC winch.. and some wetolky seat covers.
Now I'm ready to move on to 35inch tires... I think... and I want to do it right... I've been looking around and found a bunch of parts and the general direction I want to go... So I'll first start off with that list:
-G2 TJ D44 Front Axle Assembly 4.56 ratio Eaton E-Locker
-G2 TJ D44 Rear Axle Assembly 4.56 ratio; With Eaton E Locker With Disc Brakes
-35/12.50R15, ProComp Xtreme MT2*x 5
-Currie Anti rock Sway Bar Kit
-Currie Johnny Joint Adjustable Front Trac Bar
-Polyurethane Bump Stops*(figured it would be a good idea to replace these)
-Tom Woods Double Cardan Front Drive Shaft
-Tom Woods SYE kit w/Rear Drive shaft
-Currie Heavy-Duty Tie Rod System
-Centric Rotors and Black Magic Brake Pads
-Currie Rear Trac Bar
A couple of notes:
-I much rather have the simplicity of the e-locker despite the 2 pin vs 4 pin for the Dana44 ... and it is ~600 bucks cheaper then the ARB equivalent
-I plan on using the wheels I currently have*
-I also priced out just going with a super 35 and super 30 kit w/ lockers and so forth... price difference was minimal (esp considering the labor saved assembling
With all said and done with labor ... I'm looking at about 10k invested in my TJ... a bunch of dough... I want to have all my ducks in a row...
Elganja is offline
post #2 of 34 Old 03-17-2013, 01:19 PM
BYuen
BYuen's Avatar
That's a good start. I would get rid of that 2" body lift and go down to a 1". You don't really need a D44 up front. Your Dana 30 will handle 35s just fine. I would also look at upgrading your front brakes. At the very least go with Centric Premium rotors and black magic brake pads, or ideally go with the Vanco big brake upgrade kit. This allows you to run 48mm dual piston calipers from a Ford Explorer Sport Trac. I like my D44 Elocker. Works great and haven't had any issues with it for several years now.
EDIT:
Also, for 35s and the 5 speed NV3550, 4.88 gear is ideal for daily driving! I have the NV3550 and 35" tires with 4.88s and it is the perfect match.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #3 of 34 Old 03-17-2013, 01:59 PM Thread Starter
Elganja
Thanks for the info... so added to my list:
As for the gears.. I keep going back and forth with 4.56 and 4.88... I just don't like the idea of 65mph and ~2300rpm vs 2000rpm w/ the 4.88.
Hell I've dealt with 3.73's and 33inch tires for a year ... It can't be much worse then that... haha
Elganja is offline
post #4 of 34 Old 03-17-2013, 02:29 PM
TheBoogieman
JEEPS ROCK!
TheBoogieman's Avatar
You want the rpms of 4.88's.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #5 of 34 Old 03-17-2013, 02:32 PM
BYuen
BYuen's Avatar
X2. With the larger circumference and mass of the 35s, 2000 rpm at 65 is not enough.
2001 White TJ Sport
BYuen is offline
post #6 of 34 Old 03-17-2013, 04:02 PM Thread Starter
Elganja
alrighty... I'm sold
how about upper and lower control arms?
Elganja is offline
post #7 of 34 Old 03-17-2013, 04:13 PM
BYuen
BYuen's Avatar
I wouldn't run anything other than arms that have Currie Johnny Joints or Metalcloak Duroflex bushings at the ends. Anything else just doesn't last. I'm in the process of replacing my Rubicon Express control arms with arms that have Johnny Joints at both ends (gold standard of control arm ends). Rokmen, Savvy, and Currie all sell control arms with Johnny Joint ends. Metal Cloak sells their own arms. The Metal Cloaks are relatively new, so they aren't as "time proven" as the Johnny Joints, but so far no one has said anything bad about them.
If you are going to consider the Duroflex bushings, here is a good thread on them:
http://www.jeepforum.com/forum/f9/ho...ks-up-1482467/
2001 White TJ Sport
BYuen is offline
post #8 of 34 Old 03-17-2013, 04:24 PM Thread Starter
Elganja
thanks... seems like Currie is the answer to a lot of my questions... will take a look at metalcloak too
Elganja is offline
post #9 of 34 Old 03-17-2013, 04:27 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Why are you buying the front driveshaft?
Wheelin98TJ is offline
post #10 of 34 Old 03-17-2013, 04:35 PM Thread Starter
Elganja
was told it was a good time to upgrade from a stock front DS to a Tom Words Double Cardan driveshaft
was also worried about lengths going from a d30/d35 to d44/d44
Elganja is offline
post #11 of 34 Old 03-17-2013, 05:11 PM
pmcjeep
You could save a bunch of money by just doing a d44 or 8.8 rear with a front hp30 and still run 35s just fine.
01 tj 4.0,bds springs,ROKMEN arms, ecgs 8.8 and hp30 both locked with 4.88s,35in STTs,Smittybilt bumpers,8k winch,hylined MCE flatties,TKHfab rocksliders,and lots more to come!
pmcjeep is offline
post #12 of 34 Old 03-17-2013, 05:30 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
X2, thats what I will be doing with my TJ
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #13 of 34 Old 03-17-2013, 06:25 PM Thread Starter
Elganja
I've looked into that and it's nearly a wash after you add in all the parts the g2 comes with ( front d44 w/ e-locker is 2500)
Elganja is offline
post #14 of 34 Old 03-17-2013, 08:43 PM
RobsCrawlin7
no balls
A hpd30 from an xj is free or cheap. Your choice of locker, and you are good to go. An 8.8 can be had for $100, with disks and an LSD. Throw a locker in if you like and you're good to go. Total swap costs for the front $0-$100, total for the rear $800 give or take.
Even if you add arbs or ox's and gears you are still less than half of two g2's
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #15 of 34 Old 03-17-2013, 09:02 PM Thread Starter
Elganja
then add in the labor to get it all done..
I hear where you are coming from, but I'd rather get something complete from the get go and not deal with the hassle of piecing things together myself
Elganja is offline
