thinking about a spray in bed liner for my tj - Page 2 - JeepForum.com
post #16 of 18 Old 07-20-2010, 08:26 AM
2006_Sport
Raptor here. Love it.....no fading, cleans out easy, goes on nice. It could be a bit tougher but I just touch it up whenever it gets dinged. My transmission must run cooler than most because I can touch any area after being on the highway for an hour with no problem.
x2. It could be a lil thicker but it does the job for me. Upol is great stuff and if you prep and apply correctly it'll last a while. The only chips I have in it are from the 5500 watt generator I hauled back there from the repair shop and from when I dropped my hi lift jack on it. Small chips, nothing major lil duplicolor rattle can bedliner touch up will take care of it.
2006_Sport is offline
post #17 of 18 Old 07-20-2010, 08:49 AM
longbluerubi
I removed the carpet about a month ago. xtra heat not too bad. I did buy a roll of gray auto carpet at Big Lots for $8, plan to cut pieces that will generally fit to help with heat and sound (with proper holddowns of course), but plan on lining the tub first. Line-x nice (had it in a previous pickup) but real expensive. Planning on a DIY. Was thinking about an Al's Liner, heard good things about it. Still researching.
'05 LJ Unlimited Rubicon
I6 4.0L manual 6-speed
OME 2.5" lift+Nitrocharger Sport shocks
1" BL, JKS adj front & rear trackbars, JKS discos
33" BFG A/T
longbluerubi is offline
post #18 of 18 Old 07-21-2010, 07:47 AM
jshamis1
As far as the prep goes I used 220 grit sand paper to scuff everything up. They supply one green scrub pad with the kit, but I felt it wasn't going to last very long or do a good job. Once everything is scuffed up vacuumed then tape off and wipe down with Acetone. Then spay it on use low pressure like 40 lbs or less (practice on a piece of card board till you get a good pattern). I let first coat sit about an hour then did second coat, again I let it sit an hour, and then I peeled off the tape. This is a must don't let the coating dry or you will have to use a razor blade to get the masking tape off! One other tip leave your drain plugs in! Then after the tub dries use a razor to free them up! Good luck!
jshamis1 is offline
bed liner , tj , wrangler , advice , help , pros , cons
Spray in bed liner Heywoz JK Wrangler Technical Forum 5 02-07-2010 10:13 PM
Spray in box liner??? jonnyboy97 TJ Wrangler Technical Forum 13 10-15-2009 06:29 PM
Tub, spray in bed liner? jcm1983 TJ Wrangler Technical Forum 3 10-04-2008 07:10 AM
Spray In Liner LVC2003 TJ Wrangler Technical Forum 3 08-15-2007 06:55 AM
Spray in bed liner JAW_WRANGLER TJ Wrangler Technical Forum 14 04-14-2007 02:53 PM
